Codes: P2119, P2102, P1516 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-23-2008, 09:31 AM
keg keg is offline
2005 GMC Envoy SLE ~92K
Silver Mist Metallic 4.2L I6 4X4
This is my first post and I'm not sure if it should be in this forum or another.
Anyway,
I just had a scan performed and it showed the following codes:
P2119
P2101
P1516
Not sure what any of these mean other then I think there related to the throttle body.
Will cleaning the throttle body solve the problem? Or, is there some other remedy? The service engine light popped on once and was off the next day when I drove it. No other lights are on and the service engine light hasn't come back on since the first time (several days). Performance seems degraded especially when going up hills and it's stubborn when initiating passing gear.
Any steps to eliminate this problem would be greatly appreciated.
Old 12-23-2008, 09:37 AM
gordinho80's Avatar
gordinho80 gordinho80 is offline
2004 Chevy TrailBlazer LS
some more info would help... mileage, do you have an aftermarket intake, was the TB ever cleaned, etc....
Mario -
OffRoadTB.com
Old 12-23-2008, 09:42 AM
keg keg is offline
Mileage 68,000. Everything is stock.
TB has never been cleaned to my knowledge.
Correction: the title of my post indicated code P2102 and the message indicated P2101 -- P2101 is the correct code not P2102.
Old 12-23-2008, 09:59 AM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Its possible that those codes could result form a severely dirty or gummed up throttle assembly. Basically those codes indicate that the throttle position varies from the requested or commanded position by more than the allowable tolerance. Cleaning would certainly be the least expensive solution, if it works.
Other causes of those three codes together can be: Corroded, Worn, or damaged wiring/connectors to either the pedal or the throttle assembly itself, a faulty throttle body actuator or sensor or a faulty pedal sensor. If cleaning doesn't prevent the codes from returning, you're going to have to diagnose the both the pedal and throttle sensors and actuator. Somewhere there's the specifications, you connect a high-impedance VOM to the pedal and check the voltage at various openings. (You can also use a Tech-2, which makes things a bit easier).
Old 12-23-2008, 10:10 AM
rjgnwdc's Avatar
rjgnwdc rjgnwdc is offline
2007 GMC Envoy SLT
Welcome aboard new guy
No solution for your problem just say Welcome to the forum.
Marriage is a relationship in which one person is always right, and the other is a husband.
Old 12-23-2008, 04:11 PM
keg keg is offline
Thanks ylab.
I'm going to try cleaning the TB tomorrow when it's warmer outside. I hope that clears the codes because I'm not exactly sure how to go about performing the tests you mentioned and I don't have a Tech-2.
I'll respond after the cleaning.
Old 12-29-2008, 11:50 AM
keg keg is offline
I cleaned the TB over the weekend. It didn't seem very dirty, but it certainly made a noticable difference in idle and overall responsiveness.
The codes were cleared after leaving the battery disconnected for around 30 minutes while I cleaned the TB. I made a few short trips afterwards and the codes did not reappear. I'll check for codes again later this week after more routine driving.
Old 01-27-2009, 09:57 PM
jamesbt's Avatar
jamesbt jamesbt is offline
2006 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 AWD
p2101 and p1516 error codes
i see from reading the threads that the codes are tied into the throttle body and it may need cleaning but i don't know how to clean it or exactly where it is? does antone have pictures that can help???
Old 01-28-2009, 09:25 AM
keg keg is offline
The following link contains steps to clean the throttle body -- This is what I used and it's fairly easy to do.
http://forums.trailvoy.com/articles....ticle&artid=91
Old 01-28-2009, 10:37 AM
jamesbt's Avatar
Talking Thanks
I just wanted say thanks to Keg for the link. looks to be not as hard as i thought it would be or as long, again thanks.
