Originally Posted by mikepeters1983
So all I got to do to have some one pull that up for me is to put my vin up here?
well here it goes why not right: 1GNDS13S222499428
You also have open recall on this vin.
Type Number Description Posted Date Status
RC 02032 DRIVER SIDE DUAL STAGE AIRBAG INFLATOR 08/13/2002 Open
RC 03012 TRANSMISSION SHIFT LOCK AND IGNITION KEY REMOVAL OVERRIDE COMPLIANCE 05/21/2003 Open
RC 04005 WINDSHIELD WIPER MOTOR FAILURE 07/06/2004 Open
RC 04087 TAIL LAMPS/STOP LAMPS 11/16/2004 Open
VIN 1GNDS13S222499428
VEHICLE BUILD
Merchandising Model : CS15506 -2002 TRAILBLAZER LS 2WD
Gross Vehicle Weight Rating : 2520 kg (5557 lb) Order Number : FDZV2B
Build Date : 05/29/2002 Build Plant : 12206
OPTION CODES
AJ1 - DEEP TINTED GLASS AJ7 - DR/PASS FRT & SIDE AIRBAGS
AM9 - SPLIT FOLDING REAR SEAT BACK AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AXP - MPV VIN IDENT POSITION A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B86 - MOLDING B/S COLOR
CJ3 - CLIMATE CONTROL C4D - GVW RATING - 5550 LBS
C49 - ELECTRIC REAR WINDOW DEFOGGER DAY - ASSEMBLY PLANT MORAINE, OHIO
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE LOW EMISSION VEHICLE GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING DIFFERENTIAL-REAR AXLE JF8 - BRAKE VAC POWER, 4 WHL DISC
KG4 - GENERATOR 150 AMP K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
LL8 - VORTEC 4200 SFI I6 M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NP5 - LEATHER WRAPPED STEERING WHEEL
N40 - POWER STEERING N86 - FULL SIZE SPARE
QC4 - 16" ALUMINUM WHEEL QRE - P245/70R16 BW ALL SEASON TIRES
RYJ - RETRACTABLE CARGO AREA COVER SLM - STOCK ORDERS
TB4 - LIFTGATE T61 - DAYTIME RUNNING LIGHTS
T98 - STAMPING VEHICLE IDENT NUMBER UA6 - THEFT DETERRENT ALARM SYSTEM
UP0 - AM/FM STEREO W/CASS & CD PLAYER U73 - FIXED MAST ANTENNA
VP6 - NOISE CONTROL VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID EXTERIOR APPEARANCE 1SC - LS PREFERRED EQUIPMENT GROUP 3 * POWER HEATED MIRRORS * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS W/DEEP TINT REAR * CRUISE CONTROL * BODY SIDE MOLDING * LEATHER WRAPPED STEERING WHL * REAR RETRACTABLE COMPARTMENT SHADE * THEFT DETERRENT SYSTEM * REMOTE KEYLESS ENTRY
50U - SUMMIT WHITE 6SH - COMP FRT LH COMPUTER SEL SUSP
7SG - COMP FRT RH COMPUTER SEL SUSP 8EU - COMP RR LH COMPUTER SEL SUSP
9ET - COMP RR RH COMPUTER SEL SUSP 95D - MED PEWTER/DK PEWTER ACCENTS
95I - MED PEWTER/DK PEWTER INT TRIM
