Dome light replacement - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 02-20-2006, 09:49 PM
lcabyss lcabyss is offline
2004 Chevy TrailBlazer LT
Question Dome light replacement
How do I remove the dome light over to replace my dome lights? It looked like one side had a tab but I was reluctant to press and pull since I didn't want to break it. Anyone replaced them before? Thanks!
Old 02-20-2006, 10:04 PM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
Yep....its a tab....and yep.....be gentle cuz they will break. Not too gentle though. Where in VA are ya?
Old 02-20-2006, 10:34 PM
ltz03's Avatar
ltz03 ltz03 is offline
2006 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 AWD
slide a small flat screwdriver in the back and push a little hard and pull down this will remove it, the rear is a little tricky i hust removed the weatherstripping and pushed the tab i found this to be easier
Old 02-20-2006, 10:36 PM
2011 Chevy Tahoe
Oh I forgot about that rear one. ltz03 is right! Its easier to remove the weatherstripping. You can push the pin and pull, but it takes a crap load of force and it seems like it may break easily!
Old 02-20-2006, 10:38 PM
ltz03's Avatar
yeah i have put a lot of force on those things so don't be shy to
Old 02-22-2006, 08:40 PM
Thanks! I just didn't want to break the damn thing. I'll give it a go this weekend. I'm in Charlottesville, VA.
Old 02-22-2006, 08:45 PM
2011 Chevy Tahoe
Cool. Good luck with it. I hope to be installing new interior lights myself. If they get here in time.
Old 07-17-2015, 06:09 PM
Preserver Preserver is offline
2008 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 2WD
The trunk light was tricky to remove, I feared I would break the plastic. Thanks for your advice!
Similar Threads
led dome light dim when i press the light euphoric28 Interior 21 09-21-2011 02:38 PM
airbag light after fan clutch replacement ratha67 OEM Issues 3 02-25-2008 07:41 PM
Dome LED Light Question bwhite220 Interior 20 12-18-2007 08:41 PM
Dome Light Problem!!! HardWork Interior 3 01-05-2007 01:54 AM
How many forum members does it take to change a light bulb? Sport_truck Everything Off-Topic 4 08-09-2006 04:37 PM
