Stabilizer Links - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-24-2006, 08:56 PM
zx3focusguy zx3focusguy is offline
For what its worth guys, I just pulled this from SI on dealerworld. Hope this might help someone?
Document ID# 1651267
2003 GMC Truck Envoy - 4WD
Rattle, Clunk, Pop, Snap Noise From Front and/or Rear Suspension While Driving Over Rough, Uneven, Wash Board Road Surfaces (Replace Appropriate Stabilizer Link(s)) #05-03-08-007 - (Apr 25, 2005)
Rattle, Clunk, Pop, Snap Noise from Front and/or Rear Suspension While Driving Over Rough, Uneven, Wash Board Road Surfaces (Replace Appropriate Stabilizer Link(s))
2004 Buick Rainier
2002-2004 Chevrolet TrailBlazer Models
2002-2004 GMC Envoy Models
2003-2004 Oldsmobile Bravada
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1651267&pubid=305&evc=sm#ss1-1651267">Condition
Some customers may comment on a rattle, clunk, pop, loose lumber-type noise coming from the front and/or rear suspension while driving over rough, uneven roads.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1651267&pubid=305&evc=sm#ss2-1651267">Cause
The front and/or rear stabilizer links may develop additional clearance in the ball joint links, leading to a noise concern.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1651267&pubid=305&evc=sm#ss3-1651267">Correction
  1. <LI type=1>Road test the vehicle and verify if the noise is coming from the front or rear, left or right of the vehicle. It is possible in some circumstances that the noise may be coming from the front and rear suspension. <LI type=1>Once it is determined that the noise is coming from the front or rear, left or right of the vehicle, raise the vehicle on a hoist. Refer to Lifting and Jacking the Vehicle in General Information (SI Document ID #1253321). Caution: DO NOT DRIVE the vehicle on highways or at a high rate of speed while the stabilizer link(s) are removed/disconnected from the vehicle. ONLY test drive the vehicle in a parking lot or on a side street. Driving the vehicle with the link(s) removed/disconnected may reduce vehicle stability.
    <LI type=1>Remove or disconnect the suspect stabilizer link(s) from the appropriate stabilizer shaft and re-road test the vehicle with the links disconnected to verify the source of the noise.
    - If the noise is still present with the suspect link(s) removed, the source of the noise is NOT the stabilizer links. Refer to the information below for diagnostic assistance.
    Service Bulletin -- Rattle From Front of Vehicle (Adjust Hood Latch Following New Procedure) #03-08-63-003 or newer (SI Document ID #1410372)
    Service Bulletin -- Rattle Noise Under Hood (Reposition Hood Prop Rod) #04-08-63-005 or newer (SI Document ID #1527265)
    Service Information -- Suspension - Suspension General Diagnosis in the appropriate SI Document.
    - If the noise is no longer present with the suspect stabilizer link(s) removed, continue with the next step.
  2. Replace the suspect stabilizer link(s) (see parts information below). Refer to the appropriate Service Information for the replacement procedure.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1651267&pubid=305&evc=sm#ss4-1651267">Parts Information
Part Number
Description
Qty
15234065
LINK, FRT STAB SHF (07.240) - LH (INCLS 11) (2004 MY)
1
15234064
LINK, FRT STAB SHF (07.240) - RH (INCLS 11) (2004 MY)
1
88982343
LINK KIT, RR STAB SHF (07.240) - RH ST158, ST155 (2002-2004 MY)
1
88982342
LINK KIT, RR STAB SHF (07.240) - LH ST158, ST155 (2002-2004 MY)
1
12479231
LINK KIT, FRT STAB SHF (INCLS 11) 07.240 - LH (W/NUT) (2002-2003 MY)
1
12479233
LINK KIT, FRT STAB SHF (INCLS 11) 07.240 - RH (W/NUT) (2002-2003 MY)
1
Parts are currently available from GMSPO.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1651267&pubid=305&evc=sm#ss5-1651267">Warranty Information
For vehicles repaired under warranty, use:
Old 07-05-2006, 12:14 AM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
mine has 39k and I hear that awful clunking from the undercarraige.. sounds like my truck was built in 1978
  #13
Old 07-05-2006, 02:18 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
hmmmm, im close to 85,000 and no noise from underneath..... knock on wood..............
you guys change them on your own? how difficult?
  #14
Old 07-05-2006, 03:34 PM
2002BlkLTZ's Avatar
2002BlkLTZ 2002BlkLTZ is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
An easy DIY project with some basic tools. An 18mm wrench and deep-well socket are required. Getting the old ones off will require a hex wrench (don't remember the exact size) if you're lucky, and a good pair of channel locks or vise-grips and some elbow grease if you're unlucky.
  #15
Old 07-06-2006, 01:07 AM
gmcman's Avatar
gmcman gmcman is offline
Senior Member
2002 GMC Envoy SLT
Onyx Black 4.2L I6 4X4
Mine went at about 15K also, dealer replaced them after I pulled all their molars. There is a greasable MOOG replacement part but I'm not sure of the part#....hear it works well.
  #16
Old 07-06-2006, 11:17 AM
2002BlkLTZ's Avatar
Black 4.2L I6 4X4
The Moog part numbers are K6665 and K6666 for the front, and K6667 and K6668 for the rear. As mentioned above they have grease fittings and they have a nut built into the stud for installation/removal, which makes them much nicer than the OEM's which use a hex wrench to hold the stud.
  #17
Old 05-28-2007, 07:51 PM
Drummerman1 Drummerman1 is offline
New Member
2002 Chevy TrailBlazer LS
Fire Red 4.2L I6 2WD
Sway Bar Links
I think you guys might have just helped me with the rattle in my 02 TB. It's in the rear and drives me crazy! I dropped my spare and checked everything with no luck. I'll change my SB links and see. Thanks again.
  #18
Old 06-03-2007, 01:18 AM
Flawsey_Bee's Avatar
Flawsey_Bee Flawsey_Bee is offline
Olympic White 4.2L I6 4X4
Me Too
Yeah I need these like yesterday especially up front .
  #19
Old 06-28-2007, 10:44 PM
New Member
Link part #
What's the Moog part numbers for front and rear sway bar links for 02TB 2wd Can anyone help? Are they hard to change? I'm Clanging and banging like crazy!
  #20
Old 06-28-2007, 10:48 PM
New Member
Nevermind.
If I would read a little I would have found the numbers I needed from my previous post about Moog part #'s. I've got it now. I'll pick some up and get to work.
Similar Threads
Moog Sway bar End Links Ext Trail Blazer mcarso OEM Issues 10 06-21-2016 05:26 PM
Non-Moog end links...lesson learned? MichEnvoyBoy Suspension 3 10-21-2007 12:35 PM
Belltech, GF, Alignment, Camber and End Links gregsimmons Suspension 19 09-01-2007 10:19 PM
sway bar links changed and still clunk crazytb OEM Issues 5 05-01-2007 11:45 PM
MOOG Front sway Bar links Adam86 OEM Issues 10 03-07-2007 06:15 PM
