| Engine Tunes/Mods Performance Engine Tuning/Engine Modifications |
02-26-2006, 05:48 PM
Turbocharged 4.2 Project almost completed!
It's been a while since I've posted on here.. I figured I'd give you guys a good update.. We're almost done with the project.. just waiting on my MSD DIS-4 ignition system, and Kenne Bell Boost-a-pump. We're also going to try a JET Performance 4L60E controller. Basically, the DIS-4 will allow us to retard the ignition timing, so that we don't have any detonation problems under boost. We will be converting to a "wasted spark" ignition system. Basically, team up the cylinders that move up/down together to TDC, and use a single signal to fire those together. Basically, you could use 3 coils to run the engine, but, since the 4.2 has it's own coils.. you just pair the wires up together into 1, and put it to the DIS-4. So, cylinders will be teamed as such.. (1/4)(2,5)(3,6). So, basically, the teamed up cylinders will fire at EVERY revollution.. while cylinder number 1 is on it's power-stroke.. and number 4 is on it's exhaust stroke, number 1 will fire it's plug to ignite the mixture.. but 4 will fire too.. but not fire anything. Doesn't hurt anything... just simplifies the ignition.. this is how most standalone's run..
The boost-a-pump will allow me to use the stock pump, and make plenty of power.. This increase the voltage to the pump when in boost.. making it put out more volume. Works great.. and keeps me from having to drop the tank.
The trans controller plugs into any 4L60E trans harness, and allows you to modify the shift points at the push of a button.. It also comes with a shift kit. I can't wait to try this out..
Here's a few pics..
02-26-2006, 05:53 PM
2006 Chevy TrailBlazer SS Summit White 6.0L LS2 V8 AWD
cant wait to see the video (you will have a video, right) of this thing running Its cool to see someone go foward with a project like this and i'm sure that it will sick when it's all done!!!!!!
02-26-2006, 05:55 PM
2011 Chevy Tahoe Mocha Steel Metallic 5.3L V8 4X4
Can't wait to see what it does on the streets!
02-26-2006, 06:04 PM
Yes, we will have plenty of video..  Here's a crazy, 1-off 8600rpm Sentra engine that we dyno tuned yesterday..
http://www.fi-r.net/images2/500whpSQRDyno.wmv
500whp @ 19.5psi of boost.. We're shooting for 600whp on C16 and around 28-29psi. This is a custom, destroked engine, that is capable of revving to around 10K, once we get a stiffer valvespring setup.
Travs
02-26-2006, 06:08 PM
Travs
ya you'll suprise alot of people with that car oooooooooweeeeeee that looks like fun
02-26-2006, 06:11 PM
2005 Chevy TrailBlazer LT EXT Silverstone Metallic 5.3L V8 4X4
 Sounds awesome!
do u know if your gona offer a kit, and pricing on that.
02-26-2006, 06:31 PM
2007 GMC Yukon Denali Black Other AWD
trav is now called the pioneer of turbo trailblazers!!
'07 GMC Yukon Denali
220/234 .570/.588, ARH 1 3/4" with 3" ORY, PRC Doubles, LC1, TVS1900 w/ 2.8 pulley
02-26-2006, 06:56 PM
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT Onyx Black 4.2L I6 4X4
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
| Sponsored Links |
You may not post new threads
You may not post replies
