reset oil life monitor on a 2002 trailblazer - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-23-2009, 01:56 PM
hfd410 hfd410 is offline
2002 Chevy TrailBlazer LTZ
Summit White 4.2L I6 4X4
Hello Everyone,
This is my first time using any communication site.
I have changed my oil but can not reset the oil life monitor.
Please Help.
Old 03-23-2009, 02:08 PM
the roadie's Avatar
Welcome! It's in the Owner's Manual.
Old 03-23-2009, 02:11 PM
2003 GMC Envoy SLT
Welcome When you can fill out your User CP. It helps us help you. Resetting the OLM depends on whether you have the DIC or not. The info is in the owners manual or try this Thread: http://forums.trailvoy.com/showthrea...lif e+monitor Remember the SEARCH button is your friend.
Old 03-23-2009, 02:12 PM
Michblaze02's Avatar
Michblaze02 Michblaze02 is offline
2002 Chevy TrailBlazer LS
With the key in (truck off), and turned to the accessories position so that you see the red battery symbol lit up press the gas pedal to the floor 3 times within 5 seconds. On mine I don't hear any beep the light just stops showing up.
Brad-Midwest Chapter MI Rep
Old 03-23-2009, 03:37 PM
67z28's Avatar
67z28 67z28 is offline
2004 Chevy TrailBlazer LS
I can never get this to work so the light just always comes on @ start up.
Old 03-23-2009, 03:41 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
press and release the pedal slower
Old 03-23-2009, 05:20 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
we have learned that some Trailvoys will not reset by the foot method after many many many tries... some people can never get it to reset.
It is supposed to flash once reset--- but some dont...
Like mine-- I would try 10-20 times and it would not reset.
Mine has never flashed after reset either....
try this.
follow the procedure....
when you do the 3 footsteps--- do them in the 5 seconds- but do them a little slower... as in push and release slower.
once you do that - dont do anything to the vehicle- leave it as is for maybe 2 minutes...
then turn off key- restart.. and it should be done...
In the time I owned my TB from mile 0 to about 133,000 miles- I had to try the foot method- many many times- 10-20-30 times... sometimes it would not reset... Eventually from trying so many times I resorted to trying door open, door closed, headlights on, off, radio on, off.... all sorts of combinations.. but no go..
until the last time I change the oil...
where I did the 3 footsteps- and then waited a few min... and not removing the key or anything--- I think I unloaded stuff from the back-
when I tried turning off and on again- the light had finally reset on the 1st attemp no more trying over and over....
so try that... I feel your pain.
Old 03-23-2009, 05:40 PM
flip_mode's Avatar
flip_mode flip_mode is offline
2002 GMC Envoy SLT
Sandalwood Metallic 4.2L I6 4X4
display the oil life monitor on your DIC
hold down the enter button (the one with the arrow) for approx 5 seconds or until it resets to 100%
P_mЀ
Old 03-23-2009, 05:46 PM
dondude dondude is offline
2002 GMC Envoy SLT
Pewter Metallic 4.2L I6 4X4
Flip mode you the man. Worked first try.
Old 03-23-2009, 10:46 PM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Sometime I wish I had a DIC. But you learn to live without it and eventually learn the "drill".
Bill
Let's get a Meet going!
