Changing Brake Fluid - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 03-26-2009, 12:58 PM
nateb21's Avatar
nateb21 nateb21 is offline
2004 Chevy TrailBlazer LT
OK so recently I have noticed as I push the brake pedal in it almost feels like the brake lines are expanding. I am sure thats not the case but I am trying to best explain the feeling, almost like a tickingas it goes further down. So I am thinking A)bleed brakes or B)replace brake fluid. Any other ideas? Also anyone have a good procedure to replace the fluid completely?
Thanks Nate
Nate
Debadged, PCMforLESS tune, Resonator Delete with Corsa Dual Tip, Gutted Stock Air Box
Old 03-26-2009, 05:07 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
I dont think Ive seen a procedure for removing completely...
Some shops will use some machine that does this I think..
But most of us will bleed the brakes until the dark fluid begins to come out clearer. (and refilling the reservoir to make sure it doesnt go low and suck in air.
Either you do it by having a helped step on the brake while you open the bleeder screw-- or you buy one of those kits for 1 man brake bleeds.
Old 03-26-2009, 08:13 PM
2003 GMC Envoy SLT
IMO a complete job of bleeding the brakes will be a complete fluid change. Remove all the old fluid from the reservoir. Refill with new fluid. Then bleed all the wheels starting with rear pass. side, rear dr. side, front pass. side and finish with front dr.side. Make sure the res. does not get sucked empty. I replaced all the bleeder screws on my Voy with Speed Bleeders. Now I can do the bleeding without any assistance.
Old 03-26-2009, 08:33 PM
glfredrick's Avatar
glfredrick glfredrick is offline
Black 4.2L I6 4X4
^^^^ Exactly. One man operation, simple, easy, and not even expensive. Just don't get brake fluid on paint. It will make the paint go away in short order.
One other thing -- don't get excited about super high performance brake fluid. Just use the recommended type in a good name brand. Brake fluids DO NOT play well together and mixing types is the fastest way to replacing your entire system there is.
Old 04-14-2009, 06:40 PM
Jesse1 Jesse1 is offline
2003 Chevy TrailBlazer LTZ
Motive Power Bleeder
apexperformance.net
motive power bleeder
Item Qty Price Total
#0108 - GM/Late Model (1991+) & 2005
GM Bleeder: #GMBleeder
Brake Bleeder $58.46
This item was used to change the brake fluid on my TB 2003
It was posted here and I bought one. Works perfectly fine and it makes the fluid change a one man show.
Jesse1
Old 04-14-2009, 09:35 PM
jackedupcanyon jackedupcanyon is offline
2007 GMC Canyon
Steel Gray Metallic Other 4X4
Yep, agree with the process. Wheel order is not as critical but making sure the reservoir does not go empty is.
Old 04-15-2009, 09:26 AM
glfredrick's Avatar
Black 4.2L I6 4X4
Wheel order in bleeding or fluid change is worked that way because it starts with the farthest point from the master cylinder, then works back to the closest point. Otherwise, a trapped air bubble could work its way back into one of the corners. This wouldn't have to be an issue if you are just replacing the fluid, but it seems to work out best.
Old 04-15-2009, 12:49 PM
2007 GMC Canyon
Have personally done it both way on several different vehicles without a problem. The key is keeping the reservoir from running empty. Maybe I am a rare case or just been lucky, who knows. Will do furthest to closest from now on. Thanks.
You may not post new threads
You may not post replies
