Front end gear noise - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-27-2009, 08:04 AM
90profx's Avatar
90profx 90profx is offline
2007 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
2007 TB 37,000 miles, just started to notice a gear (whine like) noise coming out of the front end. You can feel a buzzing sensation in the steering wheel at 55 MPH, you can't feel anything with the car parked going through various RPM's, so I think it's safe to rule out the P/Steering pump. It's not tires because it doesn't change noise on different pavements............Any insite as to what to check and best method to check ?????? If it's wheel bearings, is that covered in the powertrain warranty ??????
Thanks all,
Gary
2007 TB LT/RS, 4.2, 4X4, Mirror LED Signals, HID Headlights, HID Fog Lights, LED Tails
Old 03-27-2009, 11:31 AM
markarock's Avatar
markarock markarock is offline
Senior Member
2006 Chevy TrailBlazer LT
Red Jewel Tintcoat 5.3L V8 4X4
Are you sure it is gear noise, and not a front hub bearing.
Do a search for "hub bearing" and read the threads. They will explain how to diagnose this condition.
Can't answer your warranty question with authority, but it sounds doubtful to me. But if you are the original owner, and noticed the noise before 36k and you only have 37k miles now, well, I suspect that you can get the dealer to take care of it for you.
Mark
3.73; G80; Bose; XM; DIC
Old 03-27-2009, 11:52 AM
90profx's Avatar
It sounded like a gear whine sound............never the less. Problem resolved, called dealer, said he'd take care of it, no charge. Dealer service tech said it was a front hub bearing..................I'm happy.................
Gary
Old 03-27-2009, 12:49 PM
markarock's Avatar
Senior Member
It's amazing. Some hub bearings last 150k miles or more, and some only last 37k. Just amazing.
Mark
Old 03-27-2009, 01:00 PM
90profx's Avatar
In talking to the service tech, he mentioned that the biggest killer for these is sudden impacts........aka those pot holes we have around here the size of a west coast sink hole. I've hit my share of those this past winter and that may have helped to shorten it's life span............
Gary
Old 03-27-2009, 01:53 PM
markarock's Avatar
Senior Member
Well, I don't buy it. If potholes were the cause of hub bearing failures, most of the cars in the Midwest would be in the shop for new hub bearings in the spring.
The bearings on our trucks are pretty stout units. They are designed to absorb the impact from hitting potholes and to keep on turning.
My suspicion is that metallurgically there have been some corners cut, or quality control isn't what it should be. In my opinion those are the two most likely candidates. But of course neither the dealer nor the mechanic nor the service folks are very likely to give you those answers. Much better to blame the customer or to blame our governments' lack of road and highway maintenance.
Mark
Old 03-27-2009, 01:59 PM
90profx's Avatar
Well put and good point....
Personally I don't care at this stage, damage is done from what ever the cause and as long as it's not coming out of my pocket, I'm a happy camper
Gary
Old 05-07-2009, 11:08 PM
07 Black Envoy 07 Black Envoy is offline
2004 Chevy TrailBlazer LS
Sandstone Metallic 4.2L I6 AWD
I know this is a few months old, but....
This is covered under the powertrain warranty up to 100k. I read the warranty certificate that I got with mine, and it states that the hub bearings are a part of the powertrain.
I have the same problem with mine (58k), just haven't had time to take it in to get replaced.
'04 Chevy Trailblazer LS
'11 Suzuki Kizashi
'03 Saturn ION 3
Old 05-11-2009, 09:52 PM
MichEnvoyBoy's Avatar
MichEnvoyBoy MichEnvoyBoy is offline
2002 GMC Envoy SLT
My OEM pass. side hub lasted 95,000 miles. I am replacing it again (already) at 115,000. Crappy aftermarket parts!
I replaced my OEM driver side the other day, it was still in good shape. Why did I replace it then you ask? I couldnt figure out which side was bad and assumed it was my drivers side, since it was original. I was wrong!
"Envoyaholic"
2002 Envoy SLT Autoride, Navigation, Dark Blue. 152,000 miles. Purchased 10/2004
