Testing Coil Packs - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-30-2009, 02:26 AM
Bradwho's Avatar
Bradwho Bradwho is offline
2005 Chevy TrailBlazer LS
Dark Gray Metallic 4.2L I6 2WD
Testing Coil Packs
Is there any way to test the coil packs for the do-it-yourselfer? I just want to make sure they are putting out what they are supposed to be. Not having any probs yet, but I am ever proactive.
Old 03-30-2009, 01:34 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
I wonder if its just better to go on ebay and buy 1 or 2 used ones- and have them as spares.. I thinks they go for $30.
that could be an even easier 'test' for when you get one fail...
just swap them.
Old 03-30-2009, 08:19 PM
2003 GMC Envoy SLT
I would think you would need a special piece of test equipment to get an accurate reading. Auto parts stores sell adapters to see if you are getting a spark.
Old 03-30-2009, 10:07 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
just swap them.
There is a seller that has new ones for roughly around $30, and they are genuine delphi coils, BRAND SPANKIN NEW!!
if you don't have an adapter, you can also wrap copper wire around the thread of the spark plug and grown the other end of the copper wire. Just make sure it doesn't touch anything else.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 03-31-2009, 12:56 AM
2003 GMC Envoy SLT
The tester I have has an adjustable air gap. The wider the gap, the more voltage being put out by the coil. But as posted earlier, I don't know how accurate it is.
Old 03-27-2011, 12:36 AM
DenaliDaddy DenaliDaddy is offline
2005 GMC Envoy Denali XL
Magnetic Red Metallic 5.3L V8 2WD
Revive... Rethink...
Hi guys, know this is an old thread, but figured I didn't need to start a new title. (Unless nobody replies to this one.)
Anyhow,
I'm wondering if anyone knows a way to bench test our coils. Like at the basic level with a multi-meter. There HAS to be a set of parameters between given pins that is a known figure. Things like resistance between pin 1 and 4, 3 and the output, whatever....
I know that some shops have a bench test unit for coils that have the ability to input voltage for a measurement at output. Not to mention the 'air gap' setting where the stronger the output, the larger the gap.
I was just wondering if perhaps there's something that's quick and easy, that would at least tell if it's dead or not.
Like a lot of us here I'm sitting around doing this... Not wanting to buy 3 coils when chasing down the dreaded "random misfire". While it first looks like it's at least on 4, I'm also suspecting 6 is acting up, and maybe even 3. Problem is, it's idling so rough that swapping a good coil to the place where there are bad ones really doesn't help that much because it'll still have a rough idle no matter where I move the dead coil(s). I'd LOVE to have 3 or 4 then put one at a time in and see how it helps.
FWIW It's got 90844 miles. Had all new plugs put in 8,000 mile ago. Thought I'd also go ahead and put all new wires in this time for $hits and giggles while I've got it turned upside down. (Well actually only the washer fluid resevoir is upside down, uh... turned on it's end that's it.)
Thanks,
DenaliDaddy
Take care,
DenaliDaddy
Old 05-17-2014, 03:00 PM
Rojo13 Rojo13 is offline
Lurking Newbie
best way to test a cop (coil on plug) system for a bad coil is to remove the suspect coil and swap it with another in a different hole. just see if the misfire code changes position. If you have a random, try checking components that affect all holes first. (EGR valve, intake gasket, fuel pump, etc.)
Old 11-22-2014, 08:21 PM
enovynick03 enovynick03 is offline
2003 GMC Envoy SLT
Pewter Metallic 4.2L I6 4X4
Hi, I'm new to this site and really need help, how can I tell if I have a bad coil vs a bad plug, I'm not getting a code for any cylinder misfire but my truck "sputters" at idle, I've cleaned the the throttle body and have had all the hoses checked an tightened. The codes are coming up as a bad cam or crank sensor
Old 11-22-2014, 10:18 PM
The Neens's Avatar
The Neens The Neens is offline
2002 Chevy TrailBlazer LS
I think I'd take care of the issues that are causing the codes first...The CPAS is a common repair for the 4.2...
http://forums.trailvoy.com/showthrea...t=62398&page=5
EFI Live by SE Performance, Derale trans cooler by me, Kooks '06-'09 header
