Checking your Oil Level - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-30-2009, 04:34 PM
etperez22's Avatar
etperez22 etperez22 is offline
2007 Chevy TrailBlazer SS (3SS)
Red Jewel Tintcoat 6.0L LS2 V8 AWD
How do you guys normally check your oil level??
Manual stated to check the oil when it is warm. Wouldn't the oil be sloshed around?
I have always checked the oil level when it is cold? or after it has been sitting for a while.
I would figure checking it cold would be the best way to get an accurate reading? I have the 5.3l engine so which is correct? If check when It is cold my oil level is in the middle.. If I check when it is warm. my oil level is over the maximum amount.
Old 03-30-2009, 04:53 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
at operating temp- shut off engine- and let it sit for a few minutes to allow oil to make its way back down to the oil pan- check oil.
Old 03-30-2009, 06:37 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Yes, my 05 manual states the same thing. I've never understand that. I've always checked the oil in my vehicles before driving in the morning.
Old 03-30-2009, 07:34 PM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
I check it when its warm.. and I also change my oil when its warm.. gets more of the stuff out
Old 03-30-2009, 08:32 PM
jackedupcanyon jackedupcanyon is offline
2007 GMC Canyon
Steel Gray Metallic Other 4X4
Check it while you are fueling your truck. Oil should be warm and will have a little time to settle while you start filling the tank.
Old 03-30-2009, 10:17 PM
GMLee's Avatar
GMLee GMLee is offline
Summit White 4.2L I6 4X4
Old 03-30-2009, 10:28 PM
Super 88's Avatar
Could someone please explain to me WHY it should be checked warm? Are you saying oil expands as it gets hot?
For many decades I've been checking it cold. That way ALL the oil has drained down into the oil pan.
Old 03-30-2009, 11:09 PM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
It should be checked at it's point of greatest volume. As all of us old school guys remember that if the crankshaft comes into direct contact with the oil in the pan the results are not good. That's why people die when they jump off bridges .... liquids are like cement at high velocities.
Bill
Let's get a Meet going!
Old 03-30-2009, 11:25 PM
Robert1101's Avatar
Yes, but do you remember the dipper sticks on the crank shaft, the splash system????? (216 chevy for one)
Robert
Old 03-31-2009, 12:02 AM
GMLee's Avatar
the reason to check your oil warm is because you should check your oil at normal operating temperature. it will give you the most accurate results. too hot, your oil level will seem a bit high. too cold your oil will seem too low. too much oil in your motor will cause a negative effect just as running a vehicle with too little oil.
