Coolant flow direction? - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-19-2009, 06:36 PM
Double D Double D is offline
2005 Chevy TrailBlazer LT
I guess I will be buying a section of clear hose to see the direction.
Old 04-19-2009, 06:39 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Good idea. Or does anyone happen to have a factory service manual who could help us with this? (Hint, Trailvoy calling Roadie - come in please!)
  #23
Old 04-19-2009, 06:45 PM
2003 GMC Envoy SLT
Read post #19. Also, on the I-6, the t-stat is in the block on the drivers side.
  #24
Old 04-19-2009, 06:51 PM
Super 88's Avatar
As to post 19 I did miss that. Actually I was hoping for a chart or diagram from the service manual.
Yes I agree with the thermostat being on the drivers side in the block - especially since I just spend a few hours changing the *** thing last week!
My point in saying "Unless I'm reading it wrong, they are saying the thermostat is in the head" is that the Haynes manual is not always accurate.
  #25
Old 04-19-2009, 06:54 PM
2003 GMC Envoy SLT
I looked through the entire Cooling section of the manual. There was no flow diagram.
  #26
Old 04-19-2009, 07:08 PM
pjaneiro's Avatar
pjaneiro pjaneiro is offline
Senior Member
2002 Chevy TrailBlazer LT
Pjaneiro, are you positive, are you will to stake a bet of you driving down here and installing e-fans for me?
Of course I am not putting anything up on the bet.
P.S. How did the lift install go?
I am so positve that it flows in that position that if you pay the plane ticket i will come....
lol
seriously the reason why i also needed to know is that i i needed to add a temp sensor, and i remember pcmforless using the lower rad hose, but after noticing that one was always cold, i decided to completly empty the rad and see if were to fill up from underneath or from the upper hose on top, well as soon as the t-stat open all the good juices came from the top hose, if uou are unsure, let teh truck idle a bit and remove you rad- cap, of course you will need to drain a bit of coolant so when i fiils up it won't overflow...
Custom K&N Cai,Custom cherrybomb dual exhaust,PCMFORLESS TUNE
DRL Re-route to fogs,5000k 50w HID LOW, CUSTOM E-FAN
  #27
Old 04-19-2009, 07:16 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Originally Posted by drolds72 View Post
Maybe not to you. I would argue that pushing the fluid up from the bottom to the top results in a more efficient cooling system. Since the fluid is going against gravity, it will stay in the radiator longer, resulting in more time to get cooled. I wish I could reverse the flow in my Cutlass, so that it runs cooler, resulting in less cylinder hotspots, and less detonation at 10.50:1, when the ambient temp is above 80.
Are you running a 3 tube rad? A good shop should be able to build you a 5 tube and cool it down quite a bit. sorry.
Robert
  #28
Old 04-19-2009, 08:13 PM
10856 10856 is offline
2003 Chevy TrailBlazer LT EXT
the coolant flows from the block into the thermostat .....the spring on the tstat is on the block side which adds to the theory that the direction of the coolant flow is from block, through tstat out to the radiator, the themostat is connected to the lower hose where the coolant enters the radiator, is forced up and out of the radiator through the upper hose, back into the block near the water pump which gives it some push through the block again ...........thats my take on it even though this thread seems to have been left with the consensus of the coolant flow in the opposite direction
'03 Trailblazer ext lt 4x4 G80 3.73 120,000 miles
  #29
Old 04-19-2009, 08:25 PM
drolds72 drolds72 is offline
Congrats for removing 2 bolts, and putting them back.
Its accurate enough for my purposes. If somebody needs a manual to change the t-stat, or even determine direction, maybe they should get a new hobby.
  #30
Old 04-19-2009, 08:44 PM
2003 GMC Envoy SLT
Just curious: How long did it take you to change the t-stat in your I-6?
