| The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here. |
06-23-2009, 09:55 PM
Senior Member
2006 Chevy TrailBlazer LT Red Jewel Tintcoat 5.3L V8 4X4
One additional tip, from personal experience.
Before popping the tapered shaft out of the steering knuckle, be sure you remove the nut completely, and then run it back on and off a couple of times so that it threads on and off easily.
I didn't do this. I popped my tie rod end loose after loosening the nut only halfway, (so that when I removed it, it would not drop down and out) (I used a pickle fork). I did this on my 03 Envoy with about 150k and many Cleveland winters. The threads were rusty and I did not PB blast them first.
Well, once the shaft is loose, it turns inside the tie rod end. I couldn't get the nut off!  I couldn't loosen it, and I couldn't tighten it. I had to jack the tie rod end back into the steering knuckle to "lock" the shaft in place. Boy was I kicking myself.
Just a word to the wise.
Mark
3.73; G80; Bose; XM; DIC
06-23-2009, 10:25 PM
2002 Olds Bravada Midnight Blue Metallic 4.2L I6 AWD
How often to replace Tie Rods
How often do the tie rods need to be replaced.Any ideas out
there?  Springbuck maybe 150K? miles.
06-23-2009, 10:42 PM
2004 Chevy TrailBlazer LT EXT Graphite Metallic 4.2L I6 4X4
I think it really depends. The more potholes you drive through the quicker they will wear. If you are a big highway user I would expect it to last a lot longer.
Mine had about 65,000 miles when they went and they were really bad.
Keith; 2004 Trailblazer EXT, 4.2l 4X4, 03 BMW 530 Sport 5-speed, 69 911T RS30 Clone, 64 Corvair,
63 Corvair Spyder
07-27-2009, 08:40 PM
2004 GMC Envoy SLT "Roadiemobile" Extreme Offroad Pewter 4.2L I6 4X4
Pics of a broken tie rod end offroad!
Just had to replace one I broke last weekend. Inner tie rod end also bent and had to be replaced. I don't expect ANYBODY doing this much damage on paved roads.
The one that broke was a Moog, but I can't blame their design, which is still stronger looking than OEM. Duralast look even stronger in the thread area still.
Tie rod carnage!
First attempt at a field splint. Ratchet handle too slippery, even with multiple ubolts.
Doesn't work to use only two ubolts and tie the threaded rod to the stub.
The INNER was even bent!
New versus old.
New one in. Carrying loctite for your field repairs everyone?
Comparison of thread treatment - Moog (bottom) , Duralast (top).
New one in.
08-09-2009, 07:21 PM
2002 Chevy TrailBlazer LS Black 4.2L I6 4X4
Anyone know the part numbers and where to get the boots for the inner tie rods? Last time I had the front end aligned, the shop ripped one of them.
Thanks
Russ
08-09-2009, 08:11 PM
Welcome. Isn't that the shop's problem?
Anyway, it's GM #26089593, a kit that includes the boot and both clamps. $60 at parts4chevys.com
Possibly available in the aftermarket - ask your local stores.
08-09-2009, 11:53 PM
2002 Chevy TrailBlazer LS Indi-GO Blue Metallic 4.2L I6 4X4
WTF did you do Bill? get a little sideways and slamthe that wheels down?
Anyway, if you still have the old inners can you measure the threads to see if the 14mm guys can run a straight swap of inner and outer? I'm gonna pick up my TB from Stainless Works tomorrow and come Tuesday I'm gonna rip it apart, again, and change the hubs cause apparently they are humming. I'll check what saize outers I have and measure my inners as well
Luis
08-10-2009, 06:25 PM
Thanks Roadie. Yes, it is the shops fault, but I never checked them after the last alignment. Using this forum (lurking quite a bit), I've changed the front springs, front & rear shocks, stabilizer links, upper and lower balljoints and outer tie rods.
When I took into the dealer for an alignment, they told me the passenger boot was torn and the inner tierod needed replacing. They could replace the tierod , boot and do the alignment for $855.00!!! I bought the inners from rock auto, but could not find the boots.
Thanks for the help.
Russ
08-12-2009, 04:59 PM
2004 Chevy TrailBlazer LT Majestic Red Metallic 4.2L I6 4X4
I'm about to do this on my '04 TB, and was just wondering: How do you stop the shaft from spinning inside the knuckle when you screw down the nut?
Thanks!!
08-12-2009, 05:06 PM
There's either a hex recess in the end of the shaft for an allen wrench, and you need to use a wrench on the nut, not a socket. Or there are two flats on the shaft on the other side of the knuckle, often hidden under the boot. Apply a wrench there.
| Sponsored Links |
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
BBK
You may not post new threads
You may not post replies
