Front end alignment - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 04-21-2009, 11:41 PM
rubberman's Avatar
rubberman rubberman is offline
2004 Chevy TrailBlazer LS EXT
Dark Gray Metallic 4.2L I6 2WD
Front end alignment
anyone else have front end alignment issues? the front left is wearing on the inside of the tire again and i had an alignment down 8 mos ago when i had new rear tires put on. is it common for the TBs to have alignment issues? i got 2 new kumhos coming this week
2004 TB EXT I6 CAI, PCM4Less PCM, Resonator delete, Kuhmo KL51
Old 04-22-2009, 02:24 AM
2003 GMC Envoy SLT
I bought my Envoy new in Sept of '02. Never been to an alignment shop and the tires are wearing perfectly. (Knock on wood)
Old 04-22-2009, 12:17 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
I bought mine in Dec. '02 and did get it aligned because I thought that after 5 years it might be a good idea. Well it did not need it after all.
Robert
Old 04-22-2009, 12:23 PM
bstromback2002's Avatar
bstromback2002 bstromback2002 is offline
Senior Member
2003 Chevy TrailBlazer LT EXT
Light Pewter Metallic 5.3L V8 4X4
Have you Lifted Or Lowered it??? If yes to either then you definantly need an alignment.
Suspension maxx 2.5 lift, Z71 springs & 1 inch spacers, Pcmforless tune, KN cold air intake, Flowmaster 50 series suv muffler, Comp Cams xr259hr
Old 04-22-2009, 12:27 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
.....I had it done after 4-5 yrs because I thought it would be a good idea (preventative maintenance), but it was right on specs.
Old 04-22-2009, 12:38 PM
blktblazer04's Avatar
blktblazer04 blktblazer04 is offline
Senior Member
Black 4.2L I6 4X4
i am also gettin inner tire wear took it to dealer to have tie rods, bearings, sway bars, balance and alignment [I]they[I]said everything checked out fine
- Justin
NorthEast Chapter
Old 04-22-2009, 01:35 PM
Senior Member
Also Wouldn't be a bad idea to check the outer tie rod ends. I have seen and sold a few of them at work.
Old 04-22-2009, 08:14 PM
rubberman's Avatar
Here are some pics of the outer tie rods. i dont know how to tell if they are bad or not.
Left
right
Left front tire with inside worn edges
Old 04-22-2009, 08:32 PM
petevw's Avatar
Well, that sure does look like a negative camber issue.
Is the shop you took it to to have it checked a well know & reliable shop? Might want to have it checked at another place.
Old 04-22-2009, 09:57 PM
rubberman's Avatar
its a reliable place. i have all the work vehicle taken there and have no issues.
