need to recharge a/c - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-22-2009, 11:20 PM
yungroyalty yungroyalty is offline
can someone tell me where the low side service port is, so i can recharge my a/c. thanks
Old 04-22-2009, 11:29 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
year make model
Old 04-23-2009, 01:08 AM
2003 trailblazer ls
Old 04-23-2009, 03:52 AM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
Its located on the Accumulator (which is next to the radiator overflow tank).. find the black cap marked with an "L"
Old 09-01-2010, 05:39 PM
GMfever GMfever is offline
2002 GMC Envoy SLT XL
Black 4.2L I6 4X4
Originally Posted by MAY03LT View Post
year make model
How about a 2002 Envoy XL. Same place as posted before?
I see black cap on a line now, front left side left of rad. No L on cap though.
Old 09-01-2010, 07:08 PM
50655 50655 is offline
Senior Member
2003 Chevy TrailBlazer LS
Dark Spiral Gray Metallic 4.2L I6 2WD
Go to the accumulator, back left corner of the engine compartment. The Envoys share the same running gear as TB's,.
Old 09-01-2010, 07:48 PM
4x4forLIFE's Avatar
4x4forLIFE 4x4forLIFE is offline
2005 Chevy TrailBlazer LS
Majestic Red Metallic 4.2L I6 AWD
Fatter line. Fallow the fatter line untill you find a black cap. Or if it works the cold one, which will be the fatter line.
K&N CAI / Jet Chips Throttle Body Spacer / 15x8 Pro-Comp Rock Crawlers / 33x12.5x15 ProComp Xterrain/ Flowmaster Super 44
Old 09-01-2010, 10:00 PM
Black 4.2L I6 4X4
Found another black cap on the silver round cylinder on back left engine compartment (accumulator)?
Then the one (black cap) that is in the line on front left of rad area (line is only about index finger thick).
Old 09-01-2010, 10:15 PM
4x4forLIFE's Avatar
Find the compressor. You should be able to and if you can't find the compressor.. turn on truck, a/c off, have someone go inside and turn the a/c on and look to see which pully makes the noise of the clutch engaging.
Ok now on the compressor there's going to be two lines coming out of it.
1 one will be fat and one skinny.. (this is compared to each other)
2 skinny line should go to condensor... the condensor is located in the front either behind or infront of the radiator. ANYWAY
3 the fatter line will go backwards towards the accumilator.
make sure your positive you got the suction side, or LOW side (fatter) line.
keep the can upright, that'll put vapor ref. into the system.
if you flip it over it'll put liquid into the system which as we all know a compressor is basically like a 1 cylinder motor so hence putting liquid into it will destroy it.
hope this helps if not try googling low side ac hook up on a 4.2 trailblazer engine.
Old 09-01-2010, 11:33 PM
Robert1101's Avatar
You do have the guage set so that you do not overcharge the system and you do know what you are doing? 134A boils around 45 below 0 (depending on the pressure) and can give nasty frostbite burns.
Robert
