Blown License Plate Light Fuse - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-26-2009, 06:40 PM
barelybenjamin's Avatar
barelybenjamin barelybenjamin is offline
2009 Chevy TrailBlazer SS
Black Granite Metallic 6.0L LS2 V8 AWD
I recently converted my rear license plate lights to 194 LEDs (along with interior lights and reverse, turn, and brake lights). I had to wire resistors in line with the turn signal LEDs but not the reverse or brake LEDs and all the LEDs work fine except for the license plate lights. The fuse for the plate lights blows immediately upon turning on the exterior lights (not DRLs). Trying to troubleshoot, I put the OEM 194s back in and the fuse still blows.
Has anyone had the same problem or similar? Or have any ideas what the problem could be?
Old 04-26-2009, 06:54 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
If the plate lights worked before you started the mod, it must be something you did.
Go back and recheck everything you touched, somewhere there is a short to ground.
Ray
Old 04-26-2009, 07:49 PM
I went back and rechecked everything. The fuse blowing is fuse 14 in the rear fuse block. The only two components attached on the neg side of fuse 14 are the license lamps (brn = pos; blk = neg)and the left rear brake light (brn = pos; blk = neg). No brn wires were harmed in the making of this mod. I only wired a resistor inline across the lt blue and blk wires (lft rear turn). I can't see how that would affect the license lamps.
Old 04-26-2009, 07:59 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
That fuse also protects the left rear tail-light (I am sure that's what you called brake light) as well. Did you change anything in that area?
Ray
Old 04-26-2009, 08:04 PM
tallcorn tallcorn is offline
? Resistor inline or across?
Old 04-26-2009, 08:06 PM
Sorry, across the lt blue and blk wires (left rear turn signal).
Old 04-26-2009, 08:12 PM
I just wired the resistor across the lt blue and black wires. And looking at the wiring diagram, that shouldn't have anything to do with the license lamps. I'm thoroughly frustrated.
Old 04-26-2009, 08:15 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Benjamin, this is a very simple circuit. The left tail light shares the fuse with the plate lights.
The left tail light shares the bulb with the left signal light.
Do you see anything common Here?
Go back and re-check the wiring.
Ray
Old 04-26-2009, 08:19 PM
Ah, crap. I completely glossed over that. Perhaps I spliced into the wrong lt blue wire, seeing how one lt blue goes to just the turn lamp and the other goes to the turn lamp as well as the brake lamp connected to fuse 14. Now where are my wire strippers...
Old 04-26-2009, 09:04 PM
Ok, so I spliced the resistor into the other lt blue wire and it still blew the fuse, and the infamous hyperflash returned. So I removed the resistor completely and the fuse obviously didn't blow.
So Any recommendations on what I can do to save the fuse? Perhaps a strategically placed resistor? I'm obviously far from being an electrician.
Or is it a compromise? Get rid of hyperflash and lose license lamps, or save license lamps but deal with hyperflash?
I'm stumped...
