Rear Ac line leak - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-28-2009, 09:26 PM
markus markus is offline
2002 GMC Envoy SLT XL
Pewter Metallic 4.2L I6 4X4
Rear Ac line leak
Hi everyone,
This is my first post, have had success searching threads in the past, Thanks
I have a 2002 SLT 4.2 XL, I charged the A'C system and it won't hold pressure and it is obviously because I have a leak in the rear line ,Low side from what I can tell heard it hissing and crawled underneath and located the leak. Can these lines be repaired or do i need to replace with new? Anyone know the rough cost and the GM part #.
Thansk Markus
Old 04-28-2009, 09:47 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Welcome aboard.
I am sure gm has a very expensive part waiting for you
But, I'd go to an automotive ac shop and get them to repair the line. Worse case, they replace it. But it will be cheaper than the dealer
Ray
Old 05-07-2009, 10:38 PM
b00ya b00ya is offline
2004 GMC Envoy SLT XL
Cranberry Red Metallic 4.2L I6 4X4
I found the same problem in my 04 xl today. Looking for part number and if the body really has to come off to replace it, it looks like it does. my leak is on the high side though.
Old 06-18-2009, 10:49 AM
sargenthp sargenthp is offline
2003 Chevy TrailBlazer LT EXT
Just found that I have a leak to the rear as well.
I am not sure if this is the correct part or not. I think it is, but the picture is hard to see. http://www.rockauto.com/catalog/rafr...&parttype=7011, ACDELCO Part # 1533010.
Old 06-18-2009, 10:14 PM
tjwisely tjwisely is offline
2003 GMC Envoy SLE XL
Graphite Metallic 4.2L I6 4X4
I just had this repair done and it wasn't cheap...but could have been worse. The shop repaired the line without freeing the body from the frame. I am going to get some pictures as soon as I can....it has been raining non stop here..so I will post them when i get them. The repair was $680, but I had the power steering drained/flush and refilled also. So about $600 for AC repair.
Old 07-05-2009, 10:27 PM
Can someone validate this?
Looks like the line that runs on the driver's side is... ACDELCO US Part # 15-33386.
Looks like the line that runs on the passenger's side is... ACDELCO US Part # 15-33010.
Then I read that you are suppose to replace the drier in case moisture got into the system. Any one know where this is and part number?
Thanks!
Old 07-05-2009, 11:30 PM
the roadie's Avatar
Compnine.com agrees:
http://www.compnine.com/index.php?u=...09&grouptype=B
The receiver/dryer/accumulator is item #26, distinctive because of the octagonal body top. GM #89040308, ACDelco #15-10411
Old 07-05-2009, 11:35 PM
Perfect. Thank you!
Old 01-05-2015, 06:06 AM
Jarome Iginla Jarome Iginla is offline
New Member
2009 Buick TrailBlazer LS EXT
Carbon Metallic Other 4X4
AC problem
Brand new air conditioning hose assemblies are quite expensive. Mostly a simple repair can save you hundreds of dollars. One way of doing so is by repairing the aluminium fittings or by replacing the rubber hose. You can get your Car ac repair done easily by any local AC Specialist.
