Another problem >:-O Replacing lock cylinder/ignition?? Pix - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-07-2009, 01:05 AM
TL_2ENV TL_2ENV is offline
2004 Chevy TrailBlazer LS
White 4.2L I6 2WD
What a day, started with springs (hence the dirty hands haha), now im trying to change out the ignition? Or lock cylinder? Im assuming its not the ignition switch because all i searched didnt help much. I took a pic, im trying to just replace the KEY part of the ignition? Along with the glove box, and driver door :-/ stuck here tho, how do i get this damn thing out, i see the tiny little clip that must be holding it on but i dont see how to depress it? Hopefully someone here has done this =[
Old 05-07-2009, 01:16 AM
White 4.2L I6 2WD
this little hole looks so perfect like it would perfectly depress that piece and slide right out, ive tried pushing in that hole in every key position pushing it in and out etc, im dumb founded, it just seems to line up so perfectly with the lil metal "clip" thing seen in pic one
Old 05-07-2009, 01:33 AM
the roadie's Avatar
The manual says push an allen key in the hole while the key is in the RUN position.
Old 05-07-2009, 01:55 AM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
ok now how did you get the covers off without taking off the steering wheel??
God I hate GM sometimes
Old 05-07-2009, 03:25 AM
White 4.2L I6 2WD
top cover has a tiny hex bolt holding it in, 4mm socket.
They were quite the bitch to line up (im super anal) I didnt want ANY gap, so that alone took me about 15 damn minutes back and fourth with all the tiny clips.
anyway i assumed RUN was all the way over, not turning the car on..lol you need to take off the battery..
turn the key as far as it will go
THe glove box lock was kind of a PITA to get out too, luckily driver door was cake
I THINK someone stole my keys, and this was the only way i could sleep at night :-/ it sucks
Old 12-16-2009, 07:28 PM
sloving sloving is offline
2003 GMC Envoy SLE XL
Black 4.2L I6 2WD
Quick Question.
My mom has a question about changing her glove box latch and was looking for instructions to do this i will be emailing her these instructions or be attempting to fix it for her when i go to see her this weekend. any help or replacing the key latch would be nice thank you in advance. PS i searched most of the forum on how to replace this before i contacted you. thanks
You may not post new threads
You may not post replies
