Bad starter solenoid - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-11-2009, 05:55 AM
Jim 951's Avatar
Jim 951 Jim 951 is offline
2002 Chevy TrailBlazer LT
Indigo Blue Metallic 4.2L I6 AWD
Hello,
Having problems starting my '02 TB, I replaced my ignition switch, only to find out that it didn't change anything. I noticed that when the trouble occured, knocking on the starter would usually help. Therefore I'm pretty sure I have a bad starter solenoid.
Starter motor looks fine, so I was thinking of replacing only the solenoid. Any advice on this?
Do you know where I can purchase the solenoid only? I usually buy parts from Rockauto because they ship to France, but they only sell whole starter assemblies.
Old 05-11-2009, 12:04 PM
CoyoteFireGuy's Avatar
CoyoteFireGuy CoyoteFireGuy is offline
Senior Member
2004 Chevy TrailBlazer LS
That sounds like a bad solenoid to me too. You cant buy just the solenoid for our trucks, you have to buy the whole starter, and they run around 200. When you remove the starter you will see what I am talking about. The solenoid is actually clip welded to the starter.
KENTUCKY REP
"I HEAR STUPID PEOPLE"
Old 05-12-2009, 06:21 AM
RunVoyRun RunVoyRun is offline
2004 GMC Envoy SLE
Silverstone Metallic 4.2L I6 2WD
Sounds ridiculous, but make sure your battery terminal connection is good. I was having a similar problem, and it was fixed by knocking on the starter (or anywhere on the vehicle). Somehow, the bump would create a connection long enough to start it occasionally. Had nothing to do with the starter or solenoid. Symptoms were comparable though.
Old 05-12-2009, 04:25 PM
Jim 951's Avatar
Thanks for the info. I had already checked my battery connection. There are 7 different starter motors on Rockauto for my TB, going from $135 to $255. Can I just go for the cheapest or do you have any other advice on this?
You may not post new threads
You may not post replies
