Can't Get Transfer Case Into Neutral!!! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > 4x4 Drivetrain
Old 05-11-2009, 01:57 PM
code422's Avatar
code422 code422 is offline
2004 Chevy TrailBlazer LT
New to this site and have found some great info, so thanks to everybody! I have an '04 Trailblazer that I bought new and have been extremely happy with it. I did encounter one problem when I was going to tow it when I was moving. After trying for several hours, I could not get the transfer case into neutral to disengage the rear axle. I remembered that there wasa time that my mother had driven my car once for about 100 miles in 4HI and wondered if that might have something to do with it. I used the directions for shifting into Neutral as described in the owner's manual, but to no avail. I have about 90k miles on the vehicle and have never gotten the diffs serviced. Any thoughts? Ideas?
Old 05-11-2009, 02:10 PM
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
The transmission was in neutral, right?
The GB ended, but PM me if you want one!
GB also ended, but PM me if you want these!
Old 05-11-2009, 02:11 PM
code422's Avatar
Yes, the transmission was in neutral. The rear axle just refused to disengage.
Old 05-11-2009, 02:15 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Mine gets picky once in a while. You need to run the switch back and forth ,with the engine off, lots of times. The contacts get dirty. Even though the light goes off does not mean the TC is in N. Shift into park and see if the truck will roll. Last time I had a problem I turned the key on, then tried to put the TC into N and that worked.
Robert
Old 05-11-2009, 02:16 PM
Robert1101's Avatar
It is the Transfer Case and not the rear end that shifts into N.
Robert
Old 05-11-2009, 02:23 PM
code422's Avatar
Sounds great. I'll give it a shot and see if I can get it to cooperate. Thanks for the advice!
Old 05-11-2009, 02:28 PM
the roadie's Avatar
The neutral position of the transfer case selector switch is the most likely to get oxidized since it's used the least. Does it light up the neutral mode light when you run through the owner's manual procedure?
Old 05-11-2009, 02:33 PM
code422's Avatar
Sometimes the Neutral indicator light would come on, though the transfer case was still engaged. At other times it would not. I've had trouble with the position light as well (ie. indicating TC is in 4HI when it has shifted into 2 wheel after driving on ice), but I've been able to resolve that by toggling the selector switch.
