Lumbar support help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 05-27-2009, 11:17 PM
Dannnny240sx's Avatar
Dannnny240sx Dannnny240sx is offline
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
Lumbar support help
i have noticed on both my front seats, the lumbar support in the back seems to be noisy when your just sitting in it. The slightest bump in the road or dip my back will lean against the seat and you can hear it for a second..
if i were to turn the lumbar knob on the side it will sound so noisy, just like the same noise i hear when not turning it. almost sounds like metal rubbing or like a metal squeal.
is it possible i can somehow get into the support in the back of the seat and like lube it up or figure out what is the noise without ripping the seat open lol
Old 05-27-2009, 11:43 PM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
didnt you have another thread about this same problem??
Old 05-28-2009, 07:40 AM
benstep11's Avatar
benstep11 benstep11 is offline
Senior Member
2004 Chevy Z71 Tahoe
Red Jewel Tintcoat Other 4X4
http://forums.trailvoy.com/showthread.php?t=57220
Apparently it was a different part of the seat. It sounds like you just need new seats...
Former MN State Rep
Old 05-28-2009, 06:08 PM
yeah its similar to the other one but different noise.
i want to know if anyone had gotten there seats upholstered, and if so how much
Old 05-28-2009, 10:17 PM
Bowhunt_Pro's Avatar
Bowhunt_Pro Bowhunt_Pro is offline
2005 Chevy TrailBlazer LS
Monterey Maroon Metallic 4.2L I6 4X4
Its not that hard to take the seat apart. remove it from the vehicle, At the bottom of the seat back there is a clip running the length of the fabric. That clip locks the fabric front and back together. Unclip it, find the 3 bolts for the upper half, 2 on one side one on the other. The side that has two bolts, the bolts will be located under the fabric up away from the bottom. Unbolt them. Locate any upper seat wiring running through the base and remove it with the upper half.
After the upper is separated you can peal back the fabric far enough to work on the lumbar device. There is a large plastic shield on the seat back frame that you can unclip and move out of the way. That is essentially a piece of spring steel on two guide rods. The spring steel flexes when the lumbar is raised using a cable hooked to a crank in the base or a motor in the top. You should be able to locate and silence your noise at that point.
If your seat has a built in air bag the ability to remove the upholstery is more limited however you can still pull it up enough to get to the lumbar.
