Bad Ignition Switch?! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-30-2009, 06:07 PM
TNsweetpea TNsweetpea is offline
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I have tried just about everything with my 02 TB...it idles rough..very rough...I have replaced the spark plugs, cam sensor, actuator, fuel filter, front O2 sensor and throughly cleaned the throttle body. Yep, it still runs rough. When I disconnected the battery to do one of the hundred things I have done to try to fix my car, the service 4WD light came on and has stayed on. Occasionally, (very rarely) I turn the key and it doesn't start but then the next try, it will start.
My TB has 120,000 miles on it...I am just tired of replacing parts and nothing changing....the rough idle is really getting on my nerves!! I have read that these cars has a lot of ignition switch problems and I've read that there are many symptoms of a bad switch...but would it effect the idle???
Thanks for any advice!!!
Old 05-30-2009, 06:12 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
No, but for $20 bucks.........
I suspect you have one, or more, dirty injectors. Try a bottle of injector cleaner.
Did you check the air filter?
If the cleaner does not help, you should have the compression checked.
Ray
the roadie's Avatar
Not certain it would kill the idle. I've heard a bad head could do it - check compression. Bad coil pack? Swap a new one into each position in turn.
But if it ever fails to crank, it's a quick and cheap replacement, so I'd just do it.
You might also post next time in the right forum not in "Latest GM News A section for industry news, recalls & technical service bulletins."
Old 05-30-2009, 06:17 PM
Black 4.2L I6 4X4
Yeah, sorry I tried to move it, but can't figure that out...I was reading the latest GM news and clicked on New Thread to ask my question...I love this forum but I have trouble figuring things out about it, like how to delete a post, move the thread, etc....
Old 05-30-2009, 06:20 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Unfortunitly, we mortals can not do any of those things.
We post in error and hope the Man On Duty does not notice
Ray
Old 05-30-2009, 06:23 PM
the roadie's Avatar
As a mod with training wheels still, I don't have sufficient power either to fix this thread. A super-mod should be along any time. They keep me on a short leash. I wonder why.
Old 05-30-2009, 06:25 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
sounds like an unleashed roadie is not a good thing
Ray
Old 05-30-2009, 06:26 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Do they speak with fear in there voice??????
Sorry,,,,,,,,,
Robert
Old 05-30-2009, 06:28 PM
Black 4.2L I6 4X4
I was pretty sure I was too "common" to fix my post!
Thanks for the advice....I've run a lot of fuel injector cleaner in the darn thing, hoping that would help...I told the guy at Autozone that I'm convinced my problem was that I had just paid it off...isn't that how it always works?!
Old 05-30-2009, 06:35 PM
dmfarms's Avatar
dmfarms dmfarms is offline
Silver Green Metallic 4.2L I6 2WD
You have new plugs, but what brand?
