A/C Blower fan will not turn off - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-03-2009, 04:26 PM
lifl2003 lifl2003 is offline
2003 Chevy TrailBlazer LT EXT
Pewter Metallic 4.2L I6 4X4
Hi all,
My 03 TB's a/c fan blows on high and will not turn off even when the power is turned off. I have been reading other similar thread and many people said that it sounds like the "speed control module". Could this be my problem.
I brought it to my local service station today and he said the part from GM is like $440.00 plus labor. I looked on the web and the speed control module is about $100.00. Am I being ripped off or could he be correct?
Old 06-03-2009, 05:38 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
have you pulled the fuse for it?
if not- pull it- and then read up some more on here.
I think Ive seen similar post before.
Old 06-03-2009, 07:17 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Yep, your being ripped big time.
The problem I'm thinking about is in the blower speed control resistor assembly.
The problem is that the fan is blowing at high speed when the key is turned off.
If that is the problem, replace the speed control resistor. This assembly for the manual HVAC is around $20
I'm not gonna take the time to look it up (but you can search on here), if you remove one of the blower fuses, the fan will stop. I think it's fuses #35 (under the hood).
If you don't pull the fuse, or the battery terminal, you will kill the battery.
Ray
Old 06-03-2009, 07:23 PM
the roadie's Avatar
They probably think it's a bad dash control module. Trailvoy knows better. It's a cheap item available in the aftermarket parts shops. No need to get it from the dealer at all.
Old 06-04-2009, 01:47 AM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Originally Posted by lifl2003 View Post
Hi all,
My EXT did that ONE time. I stopped at my friends house after a 6 hour drive. Turn the key off and the fan kept running. I was tired and at first thought maybe I hadn't turned the key all the way off or something. I tried several different things, nothing worked.
I finally tried restarting the vehicle letting it run for a few seconds and then turned the key off and then the fan turned off. I was worried that my battery might be dead the next day, but everything was back to normal.
That was about 2 years ago. Hasn't done it since. Talk about weird!
Old 06-04-2009, 04:46 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Super, in the manual HVAC speed control modules, there is a relay for the #5 speed. The relay operates in #5 and the closed contacts complete the circuit to the blower.
The relay requires the key "on" to operate, but the power for the fan (fuse #35) is a non-switched supply.
Relay contacts, sometimes arc and burn, causing a pit in the contact face. Sometimes the rough surface will freeze the contact and not release it, thus leaving the blower circuit switched on when the relay has released.
Ray
Old 06-04-2009, 05:04 PM
bigcees's Avatar
bigcees bigcees is offline
2003 GMC Envoy SLT
definitely could be the resistor,Gm has always had a problem with these being susceptible to moisture. As you will see that the new one has been changed in design it shouldn't be that much and you can replace it yourself and spend that extra money on some new mods
good luck
Old 06-05-2009, 12:43 AM
Super 88's Avatar
Thanks for the info. I almost never use the 5 position. 4 is usually high enough for the front, and 1 or 2 for the rear. But that's interesting.
Like I said it hasn't done it since (knock on wood) But at least I know where to look if it does.
Old 06-05-2009, 07:46 AM
Thanks guys
Is the "blower speed control resistor" the same as the "Speed control module" Does anyone know the part #?
Thanks again!!
Mike in NY
Old 06-05-2009, 11:07 AM
cbwilsha cbwilsha is offline
2003 GMC Envoy SLT
I'm assuming since you have the LT model that you have automatic a/c which means you need a new blower motor control module, part #89018778, which my dealer lists at $113.94. And it is no more than a 15 minute job to replace so whoever was quoting you $440 plus labor was really ready to rip you off in a major way.
Do a search above on "blower motor control module" and you will find instructions and pictures on the simple replacement procedure.
If you have manual a/c, you need the blower motor resistor. Do a search and you will find plenty of info on that option also. It is cheaper and just as easy to change.
C.B.
You may not post new threads
You may not post replies
