Leaking Washer Tank - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-09-2009, 07:09 PM
superman_79065's Avatar
superman_79065 superman_79065 is offline
Senior Member
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Leaking Washer Tank
Hey guys!
So, I have been dealing with what I thought was a leaking washer fluid tank since January. I would fill up the tank, and within several days it would be empty, with just a few uses. I haven't had time to investigate this annoying problem, so I basically went without washers until yesterday.
Finding myself with a little spare time, I disassembled the washer tank assembly. I unplugged the pumps from the tank, and they seemed fine, so I plugged the holes that the 2 pumps fit into, and filled the tank with water to find the leak. To my surprise, the tank was solid...no leaks. So, I began investigating.
I reassembled the pumps and the tank, and had my wife operate the front and rear washers while I observed. No leaks! I knew something was up, so I had my wife continue to operate the washers. Lo and behold, after a few seconds, the rear washer pump sprung a MIGHTY leak.
I disassembled it all again, and it seems the bottom housing of the rear pump, which snaps on and holds the impeller, had developed a critical crack in the body, and the o-ring that seals it to the pump motor was out of place.
I don't know if that part can be ordered separately (it's been a few years since I worked in GM Parts), and I didn't want to bother with finding out, so I decided to repair mine. Using some petroleum jelly, Gorilla Glue, and black electrical tape, I repaired the bottom housing of the washer pump. Now, we'll see how long it holds.
I'll bet that bottom housing cracked due to freezing over the winter. If any of you are experiencing a weird leak from the washer tank, this might be the culprit.
Guns don't kill people...Chuck Norris kills people.
Old 06-10-2009, 03:24 AM
the roadie's Avatar
Thanks for the report. What kind of fluid were you using in the tank and was it rated for subfreezing temps? Lots of places sell blue-tinted fluid with very little alcohol added (to keep the price low).
Old 11-16-2009, 09:20 PM
05bigblkbus 05bigblkbus is offline
2005 Chevy TrailBlazer LS EXT
Black 4.2L I6 2WD
washer fluid leak
Just realized I have the same problem. Filled my washer fluid tank and all the fluid poured right out the bottom. There are two electrical plugs at the base of the tank. I guess they're the washer motors. How do you troubleshoot to see if it is the motor or a gasket? How do I take them off and or apart?
Old 02-07-2011, 03:05 PM
mhcueball2 mhcueball2 is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I'm going to bump this one up....sorry.
How did it go? Did you have to remove the reservoir or could you fix the crack.
Mine has the same issue where it pops out of the gasket after you use it.
Old 02-07-2011, 05:34 PM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
Not on my TV but on a blazer my tank had a crack,and I fixed the crack(quicker and way cheaper).
Old 02-07-2011, 05:55 PM
m0stly_harmless's Avatar
m0stly_harmless m0stly_harmless is offline
2006 Chevy TrailBlazer SS (LS)
Silverstone 6.0L LS2 V8 AWD
It's easier if you pull off the front grille assembly and remove that headlight.
The washer pumps pop right off (pull up). You can then unplug the wires and inspect them. If you're going to toss them, REMOVE THAT LITTLE RUBBER NIPPLE - some aftermarket units DO NOT come with those (or they are different and don't sit the same)!!!
I had to replace mine as they burned out. I found that the aftermaket ones didn't sit well in the tank and the tank would empty itself just as quickly as I could fill it (yes, this was a piss off!)
I solved that problem with a bead of black silicone alone the outer edge of the nipple, sitting the pump back in and letting it dry.
I haven't had a problem since.
Old 12-02-2011, 03:36 PM
TAP119 TAP119 is offline
2003 GMC Envoy SLE
Dark Red? 4.2L I6 4X4
Leaking washer fluid when filled
The washer fluid seemed to become empty suddenly lately(no freezes yet here) and when I had a new battery installed today, my mechanic showed me the washer fluid leaking right out after the tank was filled. After a while, the leak stopped but there is still fluid in the tank.
What is the procedure for removing the tank? I can fix it or the pump(s) if damaged.
Thank you
Ted
Philly
Old 12-02-2011, 06:29 PM
2003 GMC Envoy SLT
The washer tank is the lower part of the air filter housing.
Remove the air filter cover and filter, you should be able to see the two nuts that hold the tank down.
Old 12-02-2011, 09:36 PM
2003 GMC Envoy SLE
Thank you
Thank you for the advice. I'll pull it my next day off and fix it.
Ted
Old 06-21-2015, 09:12 PM
BerthaBluBlazer BerthaBluBlazer is offline
2004 Chevy TrailBlazer LS
I just investigated a mysterious washer fluid leak and found exact same problem as OP with the rear washer pump bottom housing. Going to try to find replacement part or just rig it back together.
