| Transmission Mods Performance Transmission Modifications |
06-20-2009, 02:54 PM
2004 Chevy TrailBlazer LS EXT 4.2L I6 2WD
transmission shift linkage cable replacement?
The bushing at the transmission is worn/gone to the point the cable comes off the transmission and will leave the transmission in whatever gear you were in unless you crawl under and manually move the lever to park etc.
I have the transmission shifter cable and just need guidelines on the installation of the new cable. Seems straight forward, but never hurts to ask before starting.
This is a 2004 trailblazer ext with automatic transmission.
09-09-2009, 09:01 AM
2003 Chevy TrailBlazer LTZ Indigo Blue Metallic 4.2L I6 2WD
Did you ever get a response? I have a TB aswell and it did the same thing.
The plastic ring in the black plastic rectangular piece was broken.
I did buy some plastic shifting linkage pieces (in the help section of autozone) and one did actually fit on the pin and lock. I will try to put it inside the black plastic tranny linkage and hope it works.
I will post up results as soon as possible.
09-12-2009, 06:10 PM
2002 GMC Envoy SLT XL Light Pewter Metallic 4.2L I6 4X4
Same problem here...actually happened on our annual family outing  . I was told by the dealer that the entire cable had to be replaced...was able to get back on the road by securing the linkage with wire. Like to know if the plastic from autozone work...and how did you find the proper size...just trial and error in the parking lot of Autozone (crawling under the truck)?
09-12-2009, 08:06 PM
Yea trial and error pretty much. We were lucky it happened to break in our garage. The plastic linkage pieces are in the help section at autozone or advance auto parts. there was one that fit but it had a lip on it so i cut it off with scissors and it snapped in place. Good luck, it is a pain in the butt....also in case you did not know (i didnt) if it gets stuck in gear just jack up the truck and hit the lever towards the front of the truck. it will put it in park for you. I was scared as heck for 10 minutes thinking my truck was stuck in reverse! good luck
10-22-2009, 03:52 PM
2006 Chevy TrailBlazer LT Maroon 4.2L I6 4X4
Hello cgoodwin, I came across the same problem yesterday, I was wondering did you ever replace the shift cable? I looked on here and it seems no one has done it. Can you please give me some info on what I have to do? Thank you
05-21-2010, 08:51 PM
2002 Chevy TrailBlazer LS Sand Beige Metallic 4.2L I6 2WD
Hello;
I posted later on. You are all in luck! Im going to do mine tomorrow but I have been looking over the info I received (Chiltons Manual) and although it doesn't cover little details it seems pretty straight foreward.
Of course it starts with dis connecting the battery. for the next steps you will need a small metric socket, phillips screwdriver and a couple slot blade (regular) screwdrivers.
Take out the inside compartment in the console (6 Philipps screws) at first I couldn't see the screws (all of them) untill I took the little rubber inserts out.Lift out the compartment. Now, under that compartment there are two small screws with metric heads, I just used my 1/4" socket set with two long extensions, now, you have to remove the two cup holders in front and you will find two more metric headed screws (something the Chilton left out).
Next, using the small star end on a nut driver handle, remove the set screw in the base of the shifter knob (drivers side) and remove the knob and shift boot. Next, remove the console, you might have to un plug some of the wires I'm not going to unless I really have to! Now the end of the shift cable will be visable in front of the shifter.
Make sure the shifter in the Park position.
Jack up the car (I call my TB a car?) and make sure it isn't going anywhere by placing blocks in back of the rear wheels. Time to get grimey! crawl under and locate the cable end at the transmission, and using a flat blade screwdriver, seporate (pry) the end of the cable off the end of the trans lever (which has a locking ball on it) then next the cable assembly will be held in a bracket, you have to locate a clip near the end and pry it down to free the cable from the bracket. Now follow the cable to where it enters the floor, there is a rubber boot (part of the cable) the pushes out under the carpet.
You might have to pry up the pieces on the drivers door entrance to free up the carpet. Next, you use a screwdriver (Slot head) to pry the cable off of the shifter end (should have a retaining ball like the trans did). Pull the cable out and get ready to put the new one in.
Installation should go reverse of the removal with the exception of making sure the shifter inside is in park as well as the transmission lever.
You will notice a small clip (trans end of the cable) with with a sliding locking clip. this should be down untill you get the cable hooked up then press it up and slide the lock over it. DONE! (except for putting it back together)
Hope this helps anyone having to do this job.
Bruces 57
08-06-2010, 10:40 AM
2002 Chevy TrailBlazer LS Summit White 4.2L I6 2WD
2002 Trailblazer shifter cable bushing
I finally found just the bushing/pin needed to fix the shifter cable at the following site:
http://www.atfbilletparts.com/shifte...pair-kits-c-21
$19 and you don't need to replace the entire cable.
Hope this helps.
08-26-2010, 05:45 PM
2003 Chevy TrailBlazer LT EXT Black 4.2L I6 2WD
E
Originally Posted by rb915
This was a life saver, Thanks!
09-26-2010, 07:25 PM
2003 Chevy TrailBlazer LT Pewter Metallic 4.2L I6 2WD
Originally Posted by Bruces 57
Hello;
Bruces 57
I just got finished putting a new cable in on our 2003 TrailBlazer.
I have to credit you, Bruce 57 with an outstanding description of the process!
Thank you for taking the time to put that all down in a post.
| Sponsored Links |
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
You may not post new threads
You may not post replies
