code: P0016 with bad idle at start - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 06-23-2009, 11:32 PM
Runt Runt is offline
2004 Chevy TrailBlazer LS
Silverstone Metallic 4.2L I6 2WD
Hi to all trailvoy members I have been reading others threads, and this will be my first one. Ihave 04 4.2 tb with 180,000mi on it. I need to pass state emmisions, but SES light is on and I have P0016 code. At start it starts fine, but after a few seconds it starts to run rough and skips as if a hose is missing but its not. After a few min of driving it will smoth out and run fine.
I put in new delco plugs with gap @ .43 and cleaned the TB
I wiil be very thankful for any help with this problem.
Runt: thx
Old 06-24-2009, 12:36 AM
the roadie's Avatar
Welcome! Lots of miles for a 2004. That error relates to the camshaft position sensor being out of agreement with the crankshaft position sensor, and also could mean a bad camshaft position actuator or a loose harmonic balancer. You could start by throwing parts at the problem, but if you swap out the crank position sensor you're going to need a dealer or advanced independent tech to run a relearn procedure. If you have a trusted independent GM mechanic with a tech tool, I'd recommend you start by going there to diagnose which of the parts is the bad one. The home mechanic doesn't have access to the tools to decide which one.
Old 06-25-2009, 12:36 AM
Thanks Bill
Thanks bill for infomation 04 TB, I wiil start with getting sensors tested
Thanks Runt
Old 05-29-2011, 10:16 AM
alupparelli's Avatar
alupparelli alupparelli is offline
2002 Chevy TrailBlazer LTZ
Hi, You posted this several year ago, I have the same problem and I want know if you did get solve the P0016 code? You had to replace the cam selenoide or cam sensor or crankshaft sensor?
Thanks
Adrian
Thanks Runt
Old 11-21-2013, 05:59 PM
Povozmojno Povozmojno is offline
qwerty qwerty qwerty
qwerty 5.3L V8 4X4
Very good and*informative*exchange*..*Thank you!
