Liftgate Control Module Problem - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-09-2009, 11:46 PM
salwan salwan is offline
2005 GMC Envoy SLE
Silver Blue Metallic 4.2L I6 4X4
I took my 05 Envoy to GM today to check why the remotes doesnt work anymore, nor does the rear wiper or rear defroster, and also the liftgate does not lock when I lock all doors from inside the car. The only way to lock it is manualy.
The dealership said that the LGM (rear body control module) has gone bad. But they scaned with the computer the car and they said that there is a short circut somewhere in the ground of the car, they showed me a module that is located under back seat on the driver side (where the fuses are) and said they suspect that it caused the module to fail. Any suggestions on this issue
Thanks!
Old 07-10-2009, 07:14 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
If in fact a short has occurred it is usually in the rear liftgate where the wires are flexed repeatedly. You can search that area with a meter for continuity and look for a ground. It may be intermittent so a visual of the wires WHERE THEY PASS THROUGH OPENINGS is sometime the best bet.
The module may have failed but fuses and the short should be checked/repaired first. I believe you can get a module on Ebay for a good price. Then you get the dealer to program it to your truck
Bill
Let's get a Meet going!
Old 07-10-2009, 05:34 PM
2005 GMC Envoy SLE
Solved the problem
Thank you so much for the advise. It was a wire that was cut for some reason and it caused the module not to work. I reconnected the wire and the module is fine. thanks again
Salwan
Old 08-11-2009, 02:25 AM
Chevy492 Chevy492 is offline
2002 Chevy TrailBlazer LS
SO i have the same issue and i had some cut wires up at the top of th elift gate and i put them back together and it sounded like it locked the door but didn't turn the module back on for continous use so i was wondering how i would check for the ground to be wokring i have a a multi tester but im not sure what im looking for with it... if you know let me know what i should do im prolly gunna have to end up getting a new bcm but i had hope when i heard some action when i connected the wires back together...
Old 08-12-2009, 01:03 AM
2005 GMC Envoy SLE
I looked for Voltage where the wires are at the top of the liftgate when I was fixing my problem. 2 of the three were at 12V D/C and the 3rd one was 0V.
when you close and open the liftgate do you hear the module working? and also check if your back wiper is working after you put back the wires.
Hope this helps.
Old 08-12-2009, 02:05 AM
alright heres the update...... i checked the orange wire that goes from the lift gate to the body at the top with my tool that lights up when there is power and it wasn't lighting up so...... i checked both fuses and and on ewas blown so i replaced it and it seemed to kick the module on becaus ei could here it click....... like 5 months ago when i was messing with it the module seemed to make a humming niose and when i would close the lift gate half way it sound like the door was locking but now it does nothing........... so i was wondering which wires you tested to see if they were getting power because i think the orange at the top of the liftgate is the power and one is the ground then there are two smaller ones i believe blue and brown so which di dyou check for the 12 v current? ohh and i might add that my license plate lights are wokring so that means possible good ground? i was just wondering if im making progress in accompleshing this problem ha thanks let me know any new info that might work?
Old 08-12-2009, 05:08 PM
2005 GMC Envoy SLE
I have uploaded a picture of the wires that I checked for continuity since you have a tb and I have an envoy the wires might be different color. The wires on my truck were the small orange and brown wires(the last set of wires on the left in the picture). The license plate lights were working for me too when the module wasn't working. Check if your rear wiper is working, I believe you forgot to say if you checked it after reconnecting the wires. keep us updated. and hope this helps.
Salwan
Old 08-12-2009, 07:43 PM
ohh yeah my bad i was thinking of that when i turned off the computer last night............ no the wiper doesn't work defogger doesn't work the lock doesn't work and washer fluid as well but yes the license plate lights work ha.... but i was wondering once you tested the wires and saw that the on e was at 0v what did you do to get it working was it split somewhere? my multi reader isn't working so im going to borrow my friends tongiht and will get back with some news.... i appreciate the concern man
Old 08-20-2009, 01:38 PM
DSpoelma's Avatar
DSpoelma DSpoelma is offline
2004 Chevy TrailBlazer LT
Black 4.2L I6 4X4
First post -
I recently purchased a TB, and upon leaving with the car, the remote entry worked for a couple of days, then stopped. I figured remote battery was the issue, changed it reprogrammed the remote. Still nothing, searched the net, found this site, and began researching what could be the issue. Here is what I see: When I shut the tailgate, it acts as if the tailgate is locking, the wiper, defrost, and license plate lights all work. I checked for fuses, didn't see anything out of the ordinary - (BTW, which fuses should i specifically be looking at). I pulled off the rubber boot housing the wires last night, went through the wires, and did not feel anything that seemed like it was a broken wire, but will check continuity tonight. Any help/suggestions as to what to do next would be helpful. Thanks, and great site!
Dan
PS - when programming remote, it takes about 3 - 4 minutes of holding the lock/unlock button to get the doors to cycle lock/unlock.
Old 09-01-2009, 04:55 PM
tfair tfair is offline
2002 GMC Envoy SLE
Pewter Metallic 4.2L I6 4X4
Same Problem
Hi guys,
I've got a 2002 Envoy with the same problem(s). I've followed the thread pretty closely and have determined that the larger orange (hot) wire in the liftgate was snapped. Tonight, i'll try to get this spliced back together and see what is working or not. My question is this: the two orange wires are hot, the brown wire is a ground, the larger black wire appears to be a ground as well, but what is the small blue wire for?
I temporarily spliced the hot back together and left the tailgate up, i've seen that the license plate lamps now work, but the wipers didn't (again tailgate up, not sure if they'll work with the gate up). jumped in and programmed the keyless remote and after depressing the lock & unlock buttons on the remote, the horn sounded and i turned the key to on and off and removed the key. got out and closed the door, remote still not functional.... Curious as to if the tailgate needs to be down while programming.
Any help would be greatly appreciated. Cheers and have a great day
