IAT sensor - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 07-17-2009, 10:41 AM
rider1522's Avatar
rider1522 rider1522 is offline
2002 Chevy TrailBlazer LS
Forest Green Metallic 4.2L I6 2WD
IAT sensor
So i got a check engine light and i replaced the IAT sensor because that is what the code said was wrong. I erased the codes but not even a day later the code came back. any ideas? P0113
Old 07-17-2009, 11:12 AM
blktblazer04's Avatar
blktblazer04 blktblazer04 is offline
Senior Member
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
i had po113 and it was cuz i forgot to plug in the sensor on the intake tube
- Justin
NorthEast Chapter
Old 07-17-2009, 11:27 AM
the roadie's Avatar
Welcome, rider. I'd guess that somebody who just replaced their sensor would ensure it was plugged in at the end of the process.
One reason for P0113 could be a mismatch between IAT and ECT when the engine is cold. Have you noticed any odd behavior of the coolant temp gauge?
Old 07-17-2009, 05:35 PM
Ol' Gearhead's Avatar
Ol' Gearhead Ol' Gearhead is offline
2002 GMC Envoy SLT
New IAT sensor
I am having the same problem with the check engine light throwing the code PO113. I too have replaced the IAT sensor and the next day the code was back! I have a K&N intake filter install on my '02 Envoy.
Any body have any insight on what could be causing this code to keep coming back?
Old 07-17-2009, 05:50 PM
hatchet669's Avatar
hatchet669 hatchet669 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
check the wiring on the IAT sensor to make sure it aint melted, broken or anything?
Old 07-18-2009, 02:53 PM
2002 GMC Envoy SLT
The wiring is fine.... everything else is normal.
Old 07-23-2009, 05:41 AM
rider1522's Avatar
checked all my wires and they all look good. i am thinking about taking it to the deler cuz that light drives me crazy!
Old 07-30-2009, 05:54 AM
rider1522's Avatar
finally!!!!
So i did more research online and i found out how to fix it. my problem was the harness. I put a multimeter to the housing and was supp. get a 5 volt reading, well i wasnt so i tested the wires further down and was getting it there so i cut it and rewired the harness. problem fixed!!!
Old 08-21-2009, 08:22 PM
Dirty 30's Avatar
Dirty 30 Dirty 30 is offline
'08 SAAB 9-7x Aero
Carbon Flash Metallic 6.0L LS2 V8 AWD
Would a higher voltage read higher temps from the IAT? I moved my IAT sensor near the filter and I am still getting temps around 110-120*F with my hood open.
'08 Saab 9-7x Aero
'06 Envoy Denali - R.I.Pieces
'99 30th TA #0418
Old 08-21-2009, 08:57 PM
the roadie's Avatar
Higher voltage like from the alternator? No. Sensors like that are typically given a very precise 5 or 10V regulated reference signal generated by the PCM. No sensor would be designed to vary its signal along with system voltage like that.
