Steps to replace drivers side temp door actuator - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-21-2009, 02:03 AM
KJ_SanTanValley KJ_SanTanValley is offline
2002 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
Hello from the valley of the sun stroke. It was only 113 today! I need some help replacing the drivers side temp door actuator. Thats right, its a 113 and I have refreshing hot air coming our of my driver side vents. On a positive side, I think I have sweated off 5 lbs this week. I have the floor panels off, I see the actuator, but it appears there is no easy access. I couldn't seem to find a thread outlining the steps to make this repair. Can anyone walk me through it. I think the writing is on the wall... I'm going to have to take the whole dash off.... someone tell me I'm wrong, please
FYI: I have tried all the reset tricks and took the truck into the Chevy dealer. They are indicating that when I changed out my battery, I ceated a fault in the actualator causing it to bind up. Same problem with the Mode Door Actuator, but with help from this website, I have successfully swapped out the the mode door actuator and restored air to my front vents! One down, one to go!
Thanks!!
Kevin - 2002 TB
Old 07-21-2009, 02:19 AM
2003 GMC Envoy SLT
Welcome . I can understand why you're working on it at night. It must have dropped down to a cool 100 by now. I can only give you encouragement right now. It's late but, I'm sure someone will jump in soon. I know I've seen posts on your problem, but can't remember the answer. Sorry. Good luck.
Old 07-21-2009, 10:38 AM
JnT4life JnT4life is offline
2003 Chevy TrailBlazer LTZ
I feel your pain. Had this happen last winter with it blowing cold air instead of warm air on a cold day. After removing the lower dash as you have done, I was able to fit in a screwdriver and tap on the actuator. This broke it loose and has been working since but I don't trust it at all!
Old 07-22-2009, 12:59 AM
Thanks WOOLUF1952 for the welcome. I'm loving this website. I'm still hunting through past posts for a solution. I plan to tackle this problem again on Friday. I may just try a temporary fix (i.e. Pull the wire connection and try to manually open the door). JnT4life, I wish I was soo lucky But... you never know, I'll see if I can give it a good rattle. I'm due for a lucky break.
Old 07-24-2009, 11:19 AM
Unhappy
well... I couldn't find any threads on the actual steps for replacing the drivers side temp door actuator. To me, it looks like I need to lift the dash up out of the way to get to it. Has anyone replaced this actuator before? I saw several post on the passenger side but not the driver side ~ Thanks
Old 07-24-2009, 11:30 AM
Fefanatic Fefanatic is offline
2007 GMC Envoy SLE
Liquid Silver Metallic 4.2L I6 AWD
Air Temperature Actuator Replacement - Left Side
Removal Procedure
1.Remove the I/P carrier.
2.Remove the left side air temperature actuator (1) retaining screws.
3.Disconnect the left side air temperature actuator electrical connector.
4.Remove the left side air temperature actuator.
Installation Procedure
1.Install the left side air temperature actuator (1). Notice: Refer to Fastener Notice.
2.Install the left side air temperature actuator retaining screws. Tighten the screws to 1.9 N.m (17 lb in).
3.Connect the electrical connector to the left side air temperature actuator.
4.Install the I/P carrier.
5.Calibrate the air temperature actuator on vehicles equipped with automatic climate control (C68). Refer to Actuators Recalibration (Primary). See: Testing and Inspection\Programming and Relearning\Actuator Recalibration (Primary) - HVAC - Manual
Email me for diagrams if you need them.
Old 07-24-2010, 02:41 PM
markg63 markg63 is offline
2006 Chevy TrailBlazer LT EXT
Bordeaux Red Metallic 5.3L V8 4X4
Can you send me the diagrams for this I have to replace the actuator in my TB
Removal Procedure
Old 07-24-2010, 04:20 PM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Follow this thread. One of the best to read.
http://forums.trailvoy.com/showthread.php?t=45175
Bill
Let's get a Meet going!
Old 01-09-2014, 02:52 PM
mikeal mikeal is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
Driver side actuator
The steps listed to change and calibrate this device are great. I need to know where the driver side actuator is located. I know I am close because I have pulled the components from the center of the dash. I see the passenger's side actuater but not the driver side. Does anyone have a diagram. I am a banker by trade.... be easy.
Old 02-12-2014, 02:06 PM
0997x 0997x is offline
2009 SAAB 9-7x
Black 5.3L V8 AWD
Temp Door Actuator
I have a 2009 Saab 97x that always blows hot air out of the driver side vents. I went to the dealer, and they said that the Temp Door Actuator is bad and needs to be replaced. They said they would have to remove the dash to do this. I've read some other posts and I'm not sure the dash has to be removed to change the actuator. Anyone else experienced this?
