ball joint life - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 07-28-2009, 07:47 PM
dragoncharmer's Avatar
dragoncharmer dragoncharmer is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
ball joint life
What is the average life of front ball joints? I have 54,000 miles on my 2005 trailblazer and just noticed a clicking in the front when I turn left. It does not do it all the time, just some of the time. Could I need new ball joints already?
Old 07-28-2009, 09:23 PM
the roadie's Avatar
Clicking that's related to speed? That's much more likely to be CV joints or wheel bearings than ball joints. If it's ONLY happening with one direction of turn, look into the brake dust shields being too close to the disks (usually a scraping noise, though), or the right wheel bearing. Or is it a one-time click when you start the turn?
Stuff starts to go bad around 50K, but more goes wrong at 100K. It's a bell-shaped curve, so everything has somebody that it fails on early, and other people which never have the problem. And the mass of folks are in the middle.
If I had to say, I'd predict more ball joints are 150K sort of items, depending heavily on random chance and number of potholes in your county.
Old 07-29-2009, 04:39 AM
Black 4.2L I6 4X4
It is a one time click. I am not positive, but I don't think it is related to speed. I only hear it when I turn left, but not all the time.
Old 07-29-2009, 07:08 AM
91RS 91RS is offline
I don't know about that, my truck is one of the nicest 100k trucks I've seen and the steering was nice and tight (just as in tie-rod wear, my truck had issues with wandering because of the balljoints). However, when I decided to replace the lower ball joints since I was upgrading everything else in that area, I found mine were completely shot. Not just loose, but they have verticle movement in them with me moving the joint by hand. I would imagine in an area with bad roads or with someone who just doens't give a flip about their vehicle, they would wear out sooner than 100k.
Old 07-29-2009, 08:00 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
A one time click is probably a creak.
I'm guessing a dry bushing in a control arm (I have one right now). Mine would only creak when I go out of the vehicle, a single and small creak.
Lately, it has gotten worse and now creaks when there is a weight change (bump, dip in road).
When your turning left, the weight is off-loading on the inside corner, perhaps causing a creak.
I have oiled them, but the only long term fix is to replace.
Ray
Old 07-29-2009, 08:37 PM
Black 4.2L I6 4X4
So if it that is what it is, my wheel isn't going to fall off while I'm going 70 mph on the interstate, is it?
Old 07-29-2009, 09:12 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Nope, just a rubber bushing that moves up/down with the suspension
Ray
Old 07-29-2009, 09:31 PM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
All my Balls and Links are still Original... just need the extra $$$ to get them replaced...
Old 07-30-2009, 06:10 PM
Black 4.2L I6 4X4
Thanks RayVoy, that makes me feel better knowing that. Now I just have to hope that is what the problem is!
How many miles do you have on it MajesticLT03?
Old 07-30-2009, 07:29 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
We may be a little early (not making enough noise yet), but you can check it by bouncing the front left corner up and down.
You can probably hear the bushing complain as the control arm moves.
If it is making a noise, sometimes a squirt of WD-40 onto the bushing will quiet it for a little while (until it drys out, or gets wet).
I've mixed a little longer lasting lube by using linseed oil (month or two per application)
Ray
