Flushing and Bleeding Power Steering System - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-07-2009, 03:43 PM
eeehabt's Avatar
eeehabt eeehabt is offline
2003 GMC Envoy SLT XL
Hi all,
I got you something nice. Two PDF files explaining how to flush and bleed the power steering system in all GMC cars and trucks. It's a "DIY" process. The files are in the attachments.
I hope you like them and benefit from them.
Old 08-07-2009, 04:32 PM
a yazan's Avatar
a yazan a yazan is offline
2002 Chevy TrailBlazer LT EXT
Black 4.2L I6 4X4
A thousand thanks
Really i need it too much, I intend to flush the system after replacing the ps pumb and hoses .
Thank you eeehabt for your help and tips, i had the good fortune that you alerted me about the kind of oil used in the steering system.
the workshop put ATF oil not GM or Motorcraft
Old 08-08-2009, 10:20 AM
eeehabt's Avatar
You're welcome. I just try to find things that ease the members' lives.
Old 02-19-2017, 08:24 PM
Choppa1985 Choppa1985 is offline
2006 Chevy TrailBlazer LS EXT
Ok so i have changed the power steering pump 3 times in a 2006 trailblazer 4x4 ext with the 4.2. The pump acts like its deadheading and the last pump got so hot that the resivoir inlet actually melted shut. So i did some investigating and found several things and have talked to multiple mechanics. 1}bad rack....2}air in the system. 3}bad pump 4} need to bleed the system at the gear... so im completely lost now. Is there a bleeder on the steering box before it goes to the rack? Or no? This all started when the pressure line started to leak. Took it to a very dependable guy he replaced the bad line. Still no ps. Replaced the pump. Still nothing. Replaced the pump again. Still nothing. Today i replaced the pump and still no power steering. Can anyone help me or has anyone else had this same problem that can point me in the right direction?????? Please help!!
