How to replace your ignition switch (pics) - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 08-11-2009, 03:31 PM
mellis mellis is offline
2004 GMC Envoy SLT XUV
Majestic Red Metallic 5.3L V8 4X4
Okay, I replaced my ignition switch yesterday. I was nervous, I had read numerous posts about this, but some of them conflicted, and I wasn’t sure what I was getting myself into. I haven’t done a whole lot of work on newer car systems, although I did replace the stepper motors on my Envoy a while ago. The switch replacement was unbelievably simple, and anyone can do it.
Anyway, I decided to make this post, hopefully it’ll help someone who needs to do this in the future.
(FYI, I have a 2004 Envoy XUV, with foot pedal adjustment and tilt wheel controls on the steering column, and had no problem at all.)
First, you’ll only need two thin regular screwdrivers and the replacement switch to do the job.
Disconnect your negative battery cable. I’ve heard that you should disable the airbag, but I’ve read that others did not do this, and neither did I. Just to be safe, I tried to stay away from the front of the wheel while working on the switch.
Take one of your screwdrivers and gently pry the covers of the steering column off. They should separate pretty easily, then you just need to remove the bottom cover to get access to the switch.
Once the cover is off, you’ll see the bottom of the switch where the harness plugs in, the rest of the switch is slid up into a metal sleeve.
Take your two screwdrivers and insert them into the two holes in the metal sleeve. This pushes back the spring tabs on the ignition switch, allowing you to pull the switch assembly down and out of the metal sleeve. The pictures below have two red arrows showing where the two screwdrivers need to be inserted. The yellow circle shows where the harness connects to the switch. The last picture shows the switch removed from the sleeve, but not disconnected from the harness.
Disconnect the switch from the harness.
Look at the teeth of the old switch and compare them to the new switch. Align the new switch gear with the old switch gear. There is a gap in the gears you should see that greatly helps with the alignment.
Plug the harness into the new switch.
Insert the new switch into the metal sleeve until you hear the spring tabs engage the holes in the sleeve.
Reconnect your column cover.
Reconnect your negative battery terminal.
Start her up.
Hope this helps. Took me about 15-20 minutes to do, and most of that time was spent getting the stupid harness off the old switch.
(Moderators, feel free to relocate this post if necessary.)
Old 08-11-2009, 03:38 PM
gmac310's Avatar
gmac310 gmac310 is offline
2002 GMC Envoy SLE
Nice write up and good, clear pics too.
Old 08-11-2009, 05:05 PM
lynch55's Avatar
lynch55 lynch55 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Great contribution! I see people on here all the time with this problem and now we have a nice how-to to reference!
Old 08-11-2009, 06:58 PM
Thanks for the kind words... Like I mentioned in my post for help, this place has saved me a ton of time, hassle, and money, so I felt it was my duty to give a little back.
I noticed (just now) that I posted this under the 6 cylinder OEM issues forum, is there a way to put it into the 8 cylinder one too? (I have the 8 cylinder in my ride.)
I'm just thinking it might help even more people.
Old 08-11-2009, 07:47 PM
gmac310's Avatar
2002 GMC Envoy SLE
You could try using the edit button and then copying and pasting your first post in other sections. To be honest, I'm kind of surprised that there isn't a section just for electrical problems in general that covers all the platforms, I6 and both v8s.
Old 08-11-2009, 07:59 PM
Good idea. Did just that.
Old 08-11-2009, 08:09 PM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
I deleted it.. its already a sticky here.. so there really is no need for it in the V8 section..as it uses the exact same parts
Old 09-09-2009, 02:56 AM
Kanukong Kanukong is offline
2003 GMC Envoy SLE
Summit White 4.2L I6 4X4
Ignition switch harness
Hello,
I probably need to change the switch like everyone else as most times it will start normally. Once every 30 times or so it will have nothing, when I release and start it again it starts up, but once, it went 3 times in a row with nothing then started the fourth time. I guess I'm on borrowed time before it goes completely out. I read the post and took off the steering cover to have a looksee and with the posts I saw it should be no problem. The comment about the most time being taking the harness off the switch; so I don't reinvent the problem solving how does the harness come off? Depress one or two tabs like most harnesses?
Old 09-09-2009, 11:24 AM
the roadie's Avatar
Normal retention tab. Not an evil three-simultaneous-tabs with safety interlocks like some of the airbag connectors.
Old 09-11-2009, 02:19 PM
2003 GMC Envoy SLE
Ignition switch ordered
Okay, I ordered my ignition switch. Being in Paradise (Hawaii) no one had it in stock, I ordered it from Checkers (arriving on 17th). It is a Board Warner brand? (Phonetic spelling, not sure what it actually is) part # CS643 BWD, for $31.99. It has a lifetime warranty which is good after reading about all the failures. I looked at the AC Delco part photograph on the internet. It shows the switch as well as the wiring and harness electrical connection connected to the switch. Does it actually come with this? The way I was reading the posts you change out the switch and it seems like you reconnect the old wiring harness and connector? I guess I will also find out when my part comes on the 17th.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
You may not post new threads
You may not post replies
