Resetting the "service brake system" message - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 08-15-2009, 05:08 PM
jMo jMo is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
I got this message about the same time my e-brakes failed. I've replaced front and rear pads and the e-brakes. The warning message (and that irritating dinging noise) is still there.
I've tried pulling off the battery leads...and the radio didn't even lose its presets, much less reset the message. Brake fluid level is good. Everything seems to be working correctly. So...does anyone know how to reset this message?
Old 08-28-2009, 11:16 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Welcome to the forum!
If you pull the negative battery cable for 20 minutes minimum and you still have error messages and radio presets then you have more than one problem.
Bill
Let's get a Meet going!
Old 08-28-2009, 12:40 PM
jMo jMo is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
Thanks for the welcome and the response, Blazernut. I can't say for certain that I had the battery lead off for 20 minutes. I'll have another go at that.
There is another factor to weigh in, but as it's been an issue for several months, I didn't think it would be related. I had a bad wheel bearing, and had a shop replace it. When we got it back, the ABS light was on. The shop manager said his mechanic didn't get the sensor out of the old hub, and we'd have to come back in to get a new one.
I'll spare you the rest of the details going back-and-forth with that shop, but regardless...the ABS light was on for a few months, then my current issue started recently, with the red brake light in the display and the "service brake system" message. I assumed these were separate warnings, but perhaps they're related.
Old 08-28-2009, 12:43 PM
the roadie's Avatar
The only two inputs that cause that message (that I've read about in the shop manual) are the ebrake switch and the fluid level sensor.
You can pull the connector from the master cylinder sensor to see if it's the cause - pulling the connector should mean the same as a full reservoir.
Then pull the connector off the back of the ebrake lever - the wire is a light blue.
Old 08-28-2009, 12:52 PM
cbwilsha cbwilsha is offline
2003 GMC Envoy SLT
Pewter Metallic 4.2L I6 2WD
You erase ANY message on the DIC by holding down the erase switch on the steering wheel for several seconds while the message is being displayed. You do NOT need to disconnect the battery.
C.B.
Old 08-28-2009, 02:41 PM
jMo jMo is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
C. B. - I'll try that reset. Really looking forward to getting rid of all the dinging noise on startup.
Roadie - I tried the switch on the master cylinder, but will try the switch on the e-brake lever. Thanks. BTW, what shop manual do you use?
I didn't think I was going to get a response to this...I really appreciate all the input today!
Old 08-28-2009, 02:52 PM
the roadie's Avatar
I bought the factory Helm, Inc. manual. Not cheap, but the most complete. Sometimes available on Ebay.
Old 02-03-2015, 03:57 PM
bobbycave bobbycave is offline
Lurking Newbie
where is that erase switch on the steering wheel, I have a 2008 chevy pickup?
