[SOLVED] Transmission Fluid Change Question - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 08-16-2009, 03:42 PM
attwireless1226's Avatar
attwireless1226 attwireless1226 is offline
2005 Chevy TrailBlazer LS
Ok. So its time for me to drop the transmission pan and change the filter and fluid. The owners manual says Dextron III transmission fluid. What i would like to do is put Mobil 1 Full Synthetic ATF to fill it up (5 quarts or so). But the thing that I am wondering about is the "Dextron III fluid" is that full synthetic formula? the reason i ask is i heard that your not supposed to mix conventional and synthetic ATF fluids? is that true? Either way is the Dextron III fluid a synthetic or not? I am wondering if this is wise to do. Thanks.
Old 08-16-2009, 03:52 PM
lynch55's Avatar
lynch55 lynch55 is offline
Black 4.2L I6 4X4
You know, that's a damn good question! I'm fixing to change mine and the manual does say dex3 and 2006 says dex6, I bought mobil 1, but not 6 ,but I think it's syn. Now I'm wondering about mixing with whats already in my lines.
Old 08-16-2009, 06:47 PM
efi-diy efi-diy is offline
Senior Member
1951 GMC 3100 PU Truck
hot rod black turbo'ed 4.2L I6 2WD
If you are really keen to get more fluid out and have a garage to do the fluid change in.....
You will need an inch/pound torque wrench to do this properly
Once you have the pan and filter off loosen off all the valve body bolts - no more than 3 turns then let the transmission drip overnight. This will allow more fluid to bleed out of the torque converter. The valve body should drop and hang on the bolts. If it doesn't don't pry or pull on it!
Then snug the bolts using a nut driver starting in the middle and work outwards.
Then torque the bolts to 100 to 110 INCH POUNDS starting in the center working outwards.
Dexron 3 is fine for all transmission 2005 and earlier. GM upgraded the fluid spec to dexron 6 for the 6 speed transmissions and then applied it to all other GM transmission dating back to '49.
Turbo'ed 4200 @ 10 PSI == 510 RWHP 500 LB/FT Torque Rear wheel
Old 08-17-2009, 02:31 AM
So what are you saying? Is Mobil 1 Transmission Fluid Full Synthetic Alright You Refill With? Thanks.
Old 08-17-2009, 12:13 PM
I did a little research online and I found the answer. The answer is that conventional and synthetic fluids ARE 100% compatible with each other. This includes Automatic Transmission Fluid. It says so right on the Valvoline website (even tho i'm not a big fan of valvoline). Thats where i was able to find it. Here Is The Q&A:
Is it ok to mix synthetic ATF with a conventional and/or synthetic blend ATF?
Yes. Synthetic and conventional fluids are 100% compatible to each other.
the link for that is here: (its question number 5) http://www.valvoline.com/faqs/system...mission-fluid/
Now we can both change to mobil 1 ATF without worrying about if it is good or not to mix the two.
Old 08-17-2009, 12:29 PM
I also found on the Mobil 1 website proof to back this up. It says this (look especially at the RED):
Mobil 1 Synthetic ATF combines high-performance synthetic hydrocarbon base oils and a superior balanced additive system to provide significantly higher levels of performance above conventional fluids. This unique, advanced technology provides long drain capability, excellent friction retention, and low-temperature fluidity. Further, it helps to improve overall transmission durability and cleanliness.
Mobil 1 Synthetic ATF is also compatible with conventional ATFs.
The link for that is here if you want to take a look: https://www.mobiloil.com/USA-English...hetic_ATF.aspx
Now we can be sure that mixing ATF fluids is a safe thing to do
Old 08-17-2009, 02:21 PM
lynch55's Avatar
Black 4.2L I6 4X4
Thank you so much as I had already bought my fluid!
Old 08-29-2009, 07:17 AM
notajeep notajeep is offline
2004 Chevy TrailBlazer LS EXT
Silver Mist Metallic 4.2L I6 4X4
I topped 04 that says use dex 3 off with dex 6 and now it is slipping.
doing a fluid change today to see if it helps
Old 08-29-2009, 09:00 AM
lynch55's Avatar
Black 4.2L I6 4X4
Gee man, I hate to hear that! My owners manual says III and I have an 06 manual that came with truck and it says VI, and from what I've learned from this site VI is the preferred fluid and that's what I just changed mine out withNo slippage yet, but now I'm concerned! Please keep us posted. Did you by any chance change your filter? I did! Good luck friend
When i changed the fluid on mine i dropped the pan, let drain, take out filter, replace with new filter, cleaned out the pan with brake parts cleaner, dried the pan, put the pan back together, dumped in 4 quarts of Mobil 1 Fully Synthetic ATF: https://www.mobiloil.com/USA-English...hetic_ATF.aspx drove it for a little bit, checked the level. Showed it was a little low. added a fifth quart, drove it for 15 mins, checked the fluid again. Then it was perfect. Have been driving it for over a week & it actually shifts a little easier in my opinion. No slipping or anything abnormal at all.
In my opinion just by adding dex 6 fluid with dex 3 fluid should not cause the tranny to slip. Is it slipping Bad? I know with several GM vehicles that the trannys go slip from time to time, i have noticed this with the gmc savannas and the chevy silverados. It only slips occasionally and not bad. The mechanics call this a glitch.
On the Mobil 1 website it gives the following:
Also suitable for use in vehicles that specify the following fluid requirements:
All 2005 and earlier GM vehicles**
** Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and improved performance in 2005 and earlier vehicles, wherever DEXRON is specified.
So with that being said in my opinion i don't think that the fluid addition would cause a problem. But maybe if the fluid is extremely dirty and adding dex 6 would cause it to slip?? hard to tell. There are many people who are on this site that would probably give more answers to the solution.
Hope all goes well for you.
