spark plug change? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-21-2009, 08:20 PM
cmatb08's Avatar
cmatb08 cmatb08 is offline
2004 Chevy TrailBlazer LT
Dark Gray Metallic 4.2L I6 2WD
spark plug change?
so our TB has 83k on it as she sits if i chage the spark plugs and wirescould that possibly solve the stalling and rough idle issue that im having? every once in awhile we will get a nasty smell like a rotten egg smell but not very often. what do you guys think? if i do change the plugs what brand does everyone recommend using?
Old 08-21-2009, 08:23 PM
cmatb08's Avatar
i am also thinkin about a PCMfor less tune to change the air/fuel ratio i think it is running too lean, if it is windy outside it will shut off.
Old 08-21-2009, 09:06 PM
mikeandlara mikeandlara is offline
2002 GMC Envoy SLE
Pewter Metallic 4.2L I6 4X4
I would recommend doing one thing at a time, so you can figure out what is having the biggest impact on performance.
If you do plugs, go with AC Delco Iridium 41-103's. That seems to be the benchmark for replacement.
Try the other tune-up items as well...air filter, fuel filter, and clean the throttle body (when you do the plugs). I did all three a few weekends ago, and it shouldn't take you more than two or three hours.
There are no wires on your engine. They use coil packs that sit on top of each cylinder, which don't need to be replaced unless you are getting a miss.
I believe a rotten egg smell might point to problems with your catalytic converter. Not sure about that, but I think a mechanic can diagnose it pretty easily by checking pressures in the system. If that's bad, it's probably still covered by GM.
Hold off on the PCM tune until you get your issues addressed. You won't get the full benefit from it while you have mechanical issues.
Just my
Old 08-21-2009, 09:20 PM
flyingfischer5's Avatar
flyingfischer5 flyingfischer5 is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
You can change the plug if you feel like it, but there are rated for 100,000 miles.
The first thing i would try according to your symptoms would be to clean your throttle body. Then if that does not work you can try the plugs.
-Craig-
Northwest Chapter Vice President
Custom Tuned by ScarabEpic22
Old 08-22-2009, 12:47 AM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
They may be rated for 100,000 miles but I changed mine at 50,000 miles and it made a huge difference in performance.
The o/p is close enough to 100,000 miles that I would say by all means - change them. I used Autolite Iridium plugs, only because the AC Delcos were not available locally. I've had no problems with the Autolites.
I would agree though it wouldn't hurt to clean the throttle body.
Old 08-22-2009, 02:03 AM
cmatb08's Avatar
We cleaned the throttle body the other night it was not all that dirty than we seafoamed it so i was wondering if it could be the plugs maybe i will go for that next . I am kinda leaning toward a bad cat too.
Old 08-23-2009, 02:25 AM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
That rotten egg smell (rich) usually indicates a bad cat. other symptoms are when you're flooring it, the engine will bog down. hesitation and rough idle can also be caused by that. you can do the plugs since you're close to the 100k mark, it can still be beneficial as super88 suggested. but my guess is a bad cat.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 08-23-2009, 03:24 AM
SilveRadix SilveRadix is offline
2003 Chevy TrailBlazer LT EXT
Screw the 100k mile plug life, just change them. You don't want to wait until you're losing performance and economy. Change them before that happens. My TB has 80k and I already have the plugs so I think I might change them tomorrow.
Old 08-23-2009, 03:56 AM
cmatb08's Avatar
what would be a more benefitial for us to switch too an oem cat or pair up a high flow magnaflow cat with our magnaflow exhaust
Old 08-23-2009, 04:00 AM
wardak33's Avatar
2002 Olds Bravada
Most people that have switched to dual exhausts recommend staying single. And IIRC either way you can still only have one cat. If you can find a decent highflow cat go for it if you're looking for performance, but i personally would stick with OEM.
