Rear end clunking...Sway bar links? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 08-23-2009, 08:13 PM
jls_45 jls_45 is offline
2004 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 4X4
I have an 04 TB with 89K miles on it. I have recently started to notice some rattling/clunking noises coming from the rear end when traveling over rough roads (technical description I know). I sometimes also hear it when traveling at higher speeds down the freeway. I have read several posts on here describing that the sway bar links tend to go bad. I crawled under the truck this afternoon and there is some "play" in both rear links. I was able to twist both of them back and forth horizontally a little bit. Not sure if this is normal and also what would be considered acceptable. Are the links most likely my issue, and if so what recommendations does anyone have for replacements?
After reading this board this seems like a realtively simple repair, but any guidance is appreciated.
Thanks in advance.
Old 09-02-2009, 01:54 AM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
I just replaced all 4 Links with Mevotech units from RockAuto.com for around $80 shipped (they are greaseable too)
One of the rear links I could shake the crap out of it it was so bad... the others had some play but not as bad..
the new ones are rock solid but I of course forgot to fully tighten one front link down and it rattled like an SOB..so I fixed that.. hopefully the rattle is gone..
Old 09-05-2009, 12:23 AM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
Just got my new Raybestos front & rear sway bar bushings, and rear links from Rock Auto today. The front bushings are the blue plastic "Professional" series, which seems stiffer than the stock rubber ones (hey, ANYTHING has to be stiffer than the original 165k mile ones ).
But seriously, I'm hoping that they "tighten-up" the front end handling some. Already replaced the links in the front last year, so they should be good to go.
As for the rear, I've never replaced the links, and I also think I hear the "clunk" back there too, so I'll be replacing those links and the bushings too.
Funny though, nobody makes the rear bushings in the hard plastic.....even the Raybestos "professional" series for the rear are the black rubber. Oh well, gotta be better than the originals that are in there.
Since I was ordering all this stuff, and the shipping didn't change much, I also decided to replace my original upstream o2 sensor.....I figured after 165k miles, I got my money's worth out of it. I got the Bosch sensor, and the total bill for all this stuff w/ shipping was only $156. And they all arrived in 1 day by FedEx.....amazing!
Guess I'll be a busy boy tomorrow......got to get all this stuff on before I bolt on the new General Grabber tires I have sitting in the garage waiting for me to wear out the old Yokohama Geolanders before winter sets in.
Old 09-06-2009, 09:29 AM
regularjoe's Avatar
regularjoe regularjoe is offline
2004 Chevy TrailBlazer LT
Black 4.2L I6 4X4
That would bo my guess. Mine were replaced under warrenty at 37000 miles and now I have 78000 and I think they need replaced again this time will be with aftermarket.
Old 09-08-2009, 02:49 PM
Bay Wolf's Avatar
Bay Wolf Bay Wolf is offline
2003 Chevrolet TrailBlazer LT
Summit White 4.2L I6 4X4
I wonder if these Raybestos bushings are the same as the NAPA polyurethane ones? I know you can't completely rely on the images on these sites, but the images Rock Auto uses for the Raybestos bushings (1.72" and 1.80") are the same images NAPA uses for their bushings.
I replaced my links with Moogs and my bushings with NAPAs earlier this year, and the difference is amazing.
Old 09-11-2009, 11:14 PM
parrothead1 parrothead1 is offline
2006 Chevy TrailBlazer LT
Broken link in rear suspension
Hi, I had the same symptoms ever since i bought mine used. Finally looked underneath the vehicle tonight and one of the links is broken. I don't know what to call it. It is the one that connects the rear axle and runs forward to an anchor point on the frame. It had been acting funny towing a trailer, but the final straw was when I was experiencing "torque steer" when accellerating in 2wd. That's not supposed to happen. I have an aftermarket powertrain warranty. I am guessing it is not covered. If not, looks like an easy repair. Where can I find one of these (not junkyard)? Part stamped with #24205151. Can I do this in my garage or do I need to put it on a lift?
http://www.facebook.com/photo.php?pi...&id=1020209506 For the picture.
Old 09-12-2009, 02:03 AM
the roadie's Avatar
Welcome!
WHO did the prepurchase inspection on this death trap!?!?!?!?!?!?
Fire them.
If it was you, and you didn't pay a mechanic to look it over, please be an example to everybody to not do this.
You could have died. You are (even now) only a 1" bent piece of flat sheet metal (the wussy upper control arm) away from losing your rear axle on the Interstate.
Seriously - don't tow. Don't drive over 20 MPH and even then on deserted streets.
I personally would get one from a recycler. www.car-parts.com is a portal. Or Ebay. I don't know that part number you have, but the one I have listed is GM #15098154. $122 at parts4forchevys.com. Other vendors like Spohn Performance make them for $120.
http://www.spohn.net/shop/2002-2009-...Envoy-SSR.html
Old 01-21-2010, 09:11 AM
Trailblazer88's Avatar
Trailblazer88 Trailblazer88 is offline
2006 GMC Envoy Denali
Summit White 5.3L V8 4X4
I have a nosie from the pass. rear. I went under the truck last night and shook the spare tire and thats on nice and tight. I took a rubber mallet and hit a few things and everything seemed tight. I grabbed hold of the swaybar link and was able to twist it side to side very easily. It that a sign that its bad and is whats causing the noise?
Old 01-21-2010, 07:17 PM
2003 GMC Envoy SLT
That is most likely the noise maker. The rear sway bar end links are the easiest to replace.
