02 envoy serpentine belt - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 09-07-2009, 03:32 PM
glenjw1969 glenjw1969 is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 2WD
Hey all-
How difficult is replacing the serpentine belt on an 02 Envoy SLT? Should I take it to the shop or is it readily accessible w/o too much trouble?
-Glen
Old 09-07-2009, 04:25 PM
91RS 91RS is offline
It isn't too dificult, you just need a 3/8 ratchet (long handle is better) and there's a square hole in the tensioner the ratchet will go straight into and then you can move the tensioner and remove the belt. Make sure you make a diagram of how the belt routs before you take it off if you're forgetful! Do it when the truck is cold, that way you won't burn yourself.
Old 09-07-2009, 05:06 PM
lynch55's Avatar
lynch55 lynch55 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Very easy! Even a cavem-----well you know what I mean
Old 09-07-2009, 05:21 PM
Hal's Avatar
Hal Hal is offline
2003 GMC Envoy SLT
Polo Green Metallic 4.2L I6 4X4
Page 28 has the drawing of the belt routing.
http://media.gm.com/division/powertr.../4200_Tech.pdf
You may want to consider replacing the idler pulley while you have the belt off. It's not very expensive and only one bolt.
You Ain't Heard Nothin Til You've Heard a Holley 750's Secondaries Suckin Air.
Old 09-07-2009, 06:46 PM
I wouldn't worry about the idler pulley, those aren't a problem on an 02. I think those didn't become a problem until 05.
Old 09-07-2009, 08:39 PM
2002 GMC Envoy SLT
Thanks!
Wow- thanks for the advice!
I've got some front end damage to repair (grill and headlight) so I think I'll make a project of it and do plugs, belt, and clean out the throttle body as well.
Hope this helps my rough idle... I've read a few posts and it sounds like a common issue.
Thanks for all the helpful comments here and in my other posts!
-Glen
Old 09-07-2009, 09:40 PM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
Isn't their two sizes of belts(depending which amp alt. you have?)How do you know which one you have(is it stamped on it?)havn't looked at it yet.I have a LTZ that's loaded so I guess I have the bigger alt.
Old 09-07-2009, 09:43 PM
There's one for SWB and one for LWB.
Old 09-07-2009, 09:57 PM
lynch55's Avatar
Black 4.2L I6 4X4
They are different belt sizes for LS and LTZ According to AutoZones website.
Old 09-08-2009, 12:12 AM
2003 GMC Envoy SLT
The long wheel base gets the short belt. The difference is the size of the PS pump pulley.
