CV Inner Shaft Oil Seal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-08-2009, 01:11 AM
JerseyWreckDive JerseyWreckDive is offline
2002 Chevy TrailBlazer LS
Easily scratched Green 4.2L I6 4X4
I had to put in two new CV Shaft/Assemblies and figured I change the oil seals at the same time. Did the drivers side and it seamed a little loose fitting, but I figured, maybe it will swell a little... and didn't do the passenger side at the time.
Well I had to do the lower ball joint on the Passenger side this weekend and figured I'd pull the CV shaft and change the seal since I had it. I get under the truck and the the drivers side is soaked with fluid. The new seal's been leaking like a sieve. So I continue on with the passneger side and when I get to the seal, it's about 3/8" too freagin small for the shaft. I pull the other side, figuring maybe the drivers and pass. are different size shafts and I screwed it up but it's too small for the drivers side too.
I looked up the GM part #12471617 and it says it's for the 02 -08 Trailblazer.
WTF? It was a sealed package. This truck is the Early 2002 (as in Sept. 2001) is there a different part #?
Old 09-08-2009, 07:33 AM
rmsg0040 rmsg0040 is offline
Senior Member
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
I changed my drivers side axle seal couple months ago. The part number is 12471618.
Old 09-08-2009, 08:07 AM
91RS 91RS is offline
Did you get them from the dealer?
Old 09-08-2009, 08:44 AM
markarock's Avatar
markarock markarock is offline
Senior Member
2006 Chevy TrailBlazer LT
Red Jewel Tintcoat 5.3L V8 4X4
Check out these threads:
http://forums.trailvoy.com/showthread.php?t=45202
http://forums.trailvoy.com/showthread.php?t=60299
Mark
3.73; G80; Bose; XM; DIC
Old 09-08-2009, 11:25 AM
Originally Posted by markarock View Post
I've got exactly the part number your talking about. It's way too small.
Kyle
I'll never buy another GM product as long as I live.
