Type of Engine Oil - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-09-2009, 03:33 PM
rwyatt80 rwyatt80 is offline
2004 Chevy TrailBlazer LT
Type of Engine Oil
Hello,
I have an 04 Trailblazer 4.2l with 127,000 miles and its time for an oil change. I wonder if there is a particular brand (castrol, valvoline etc) that is preferred over others. Because it has so many miles, do I need to be looking at the high mileage engine oil?? What weight would be good for the vehicle? I dont haul anything, I live in SC and take long trips every once in a while. Any help is appreciated.
Str8 Blazin
Old 09-09-2009, 03:47 PM
Urbanarkansas's Avatar
Urbanarkansas Urbanarkansas is offline
2003 GMC Envoy SLT
any noticeable oil leaks?
If it were me, I would put a premium (mobile1, Valvoline, RotellaT) high mileage oil in. Always go with what the manufacturer reccomends (5w-30).
I myself put Valvoline Max Life semisynthetic 5w-30 in at each oil change.
Make sure you get a good filter too. Wix is my favorite...
South Chapter Member
Arkansas Co-Rep.
Old 09-09-2009, 05:07 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
I switched to full synthetic at 135k miles with mobil1 5w-30 and i couldn't be happier with the way the engine performs. I took the chance doing the switch at a high amount of miles though. Some may get lucky, some don't. Just stay away from Pennzoil platinum and quaker state.
Also, the poster above makes a good point. A good oil filter will only be beneficial. I personally use mobil1 but anything like wix or puralator is good as well.
5w-30 is recommended in these engines but if you're in a warmer climate you can do 10w-30
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 09-09-2009, 05:31 PM
Type of Engine Oil
I will try mobil 1 or valvoline high mileage with a purolator filter. I will go with 5w-30. Thanks for such a quick response!!! I will keep you posted.
Str8 Blazin
Old 09-10-2009, 12:13 AM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Why do you say that? You aren't going to bring up the old wives tales - are you ?
FWIW, I've used Pennzoil Platinum in many of my vehicles and it is a very good oil. Over at BITOG it is also very high regarded!
Old 09-12-2009, 03:24 PM
Engine Oil
I use penzoil 10w40 high mileage. I keep hearing that it isnt good for my car, why is that?? What is wrong with penzoil? I dont have a problem switching to 5w30, just like to hear different opninons..
Str8 Blazin
Old 09-12-2009, 03:38 PM
BLAZEN03's Avatar
BLAZEN03 BLAZEN03 is offline
2003 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Personally I like Mobil 1 fully syn with Mobil filters, but on this truck I've stuck with castrol 10w30 they only had 5 of the 7 qts I needed, I know the owners manual says 5w30, but right below that it reads, you can use 10w30 if 5w30 is not available. However I did use Fram's high milage oil filter, recommended over 75,000..(I have 95,000..I don't know if it's that much better, but I didn't want the cheapest filter.
Old 09-12-2009, 04:37 PM
Super 88's Avatar
I'm not disputing what you are saying, but I find it interesting that in later manuals (my 05 in particular) they deleted that and said something to the effect of "Do NOT use SAE 20W-50 or any other viscosity . . . "
Many years ago - decades even, Pennzoil somehow got a bad rap for causing sludge. I've seen a lot of people go many 100's of thousands of miles using Pennzoil. EVEN IF it was true in the 60's or 70's I do not believe it is still the case.
On the other hand, I've used Mobil 1 in many of my vehicles and let's just say I was NOT impressed. Especially in the TB, the engine was noiser, the power was less and I believe the MPG dropped a little - not a lot but a little.
I think Pennzoil Plat. works better and it is a lot less money! 5 quart jugs at Wallymart are 20.00 and recently they had a 15.00 rebate!
As with many things, it is mostly a subjective thing. What works for one person may not work well for another.
Personally I like the A/C Delco oil filters. Unlike others I will not say "Fram is bad" because again I've used them for many decades over many hundreds of thousands of miles with NO problems ever!
However I do believe there are better filters out there for the same or less money. Purolator and Wix are two that come to mind.
Old 09-12-2009, 06:58 PM
I haven't had any leaks or anything since I've switched to penzoil hm years ago. I use fram filters, but will look into purolator as I have used it in the past. Thanks for the quick response. Will let u know the outcome after I change my oil monday.
Old 09-12-2009, 08:08 PM
wardak33's Avatar
2002 Olds Bravada
Really? I've read threads on BITOG and they mentioned that it does some crazy things to your valves..
You may not post new threads
You may not post replies
