Driver's side carpet soaking wet! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-17-2006, 08:41 PM
TBlazeruss44's Avatar
TBlazeruss44 TBlazeruss44 is offline
Senior Member
2004 Chevy TrailBlazer LS
I just got back from the dealership's service dept. today after picking up my '04 TB LT for warranty work...The floor on my driver's side has been soaking wet!!! The service mgr. said that they have someone from outside the dealership they call a "leak expert" come in one specific day a week (Fridays) to determine the water entry source and instruct the in-house service techs on how to correct the problem...According to the slip that I received from the service mgr.upon picking up my truck,the guy determined that there was "insufficient sealant on left cowl panel FC-2P,sublet repair .2 hr to integrity water seals.Reseal left cowl panel for open seam".It's too early to tell if the "hired gun" has fixed the leakage, but I will fill y'all in a little down the road on this one, for sure...Has anyone else on the TrailVoy site experienced this particular problem??? I have heard of this occurring on the passenger side due to A/C condensation drainage, but not on the driver's side of theTB...Any further input from anyone whose had the same experience on the driver's side floor, I'd sure love to hear from ya'...Hopefully all will be well because I LOVE my TB!!!!
~Eric~ PCMforless tuned (again) and still loving it!!!
Old 03-17-2006, 10:01 PM
AbuAbdulAziz's Avatar
AbuAbdulAziz AbuAbdulAziz is offline
International Chapter
Just Silver ! 4.2L I6 4X4
Well, NEVER had it with my Truck, but have had it with my old 98 Mercedec though, i know it suck's big time
Old 03-18-2006, 03:23 PM
Rob Rob is offline
2003 Chevy TrailBlazer LTZ
I haven't looked on my TB, but most cars I've seen have a drain tube for the A/C unit. When they get plugged the water ends up on the floor. Look for a little tube going through the firewall and pointing down. clean it out with pipe cleaner or some compressed air.
Old 03-18-2006, 03:58 PM
thor's Avatar
thor thor is offline
2002 Chevy TrailBlazer LT EXT
my 2002 trailblazer LT "EXT", had a leak on driver side dealer couldn't find it, i did, it was the door seal moulding, the rubber seal, had a sag in it,let water run in
Old 03-18-2006, 04:56 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Haven't had a leak but it does make sense to me as a possible source. I 've had my wiper arms and air inlet cowl cover off to get to the wiper motor ass'y to do my own wiper motor seal mod to my '02, and I did a very close inspection while I had it apart. They use an expanding foam sealant looking stuff along all the panel seams during assembly. If there was a gap in the sealant where they missed a spot on the driver's side, water coming in down through the air inlet grill or down the windshield could leak in. Good luck - hope they get it the first time.
Old 03-18-2006, 08:28 PM
the roadie's Avatar
This doesn't address the OP's problem, but the TB/E A/C condensate tube is on the passenger's side. My passenger's carpet got soaked last summer, and it wasn't that the drain tube was plugged with mold or debris. The A/C plenum in the engine compartment just in front of the firewall is where the drain tube plugs in. If that tube falls down a tiny bit, and isn't pushed into the hole hard enough, it has an internal baffle that shuts the drain hose. Then the condensate backs up into the passenger side and runs under the carpet.
Now I wiggle that tube upwards into the hole every month or so to make sure Mrs. Roadie's toes don't get wet.
Old 03-27-2006, 02:48 PM
Rainman's Avatar
Rainman Rainman is offline
2002 GMC Envoy SLE
Black 4.2L I6 4X4
I don't have the answer but something similar did happen to me. Two weeks ago, my '02 Envoy was in the dealer ship for body repair. I had a new pair of leather gloves underneath the driver's seat and noticed that they were soaked. Checked the floor and it was soaked, mostly under the seat. Weird cause everything around the wet section was dry, including the seat above. It had no odor, nor was it oily, just H2O. I donít think itís a big deal, probably just aliens playing games with me. I was supposed to keep an eye on it but forgot so Iíll check tonight and after my next high pressure care wash.
Old 03-28-2006, 11:33 AM
wdltb2004 wdltb2004 is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Well I jumped in my Trailblazer today and to my suprise there were a few drips on the seat. Look up and there is water on the right plastic mount of the visor. I wiped it off and begin to drive, next thing I know noah let's the water loose and I look like I've wet myself.
This isnt the first time I've had water leaking somewhere inside the cab. Bout 2 months ago I had a huge amount of water leaking through the upper console. Needless to say when I head home from school this weekend I will be making a stop at the dealer to have a little talk about my new leaking issues.
By the way I have an 04 Lt with a sunroof. I'm assuming that the water is coming either through the sunroof or through the antennae on the top right next to the sunroof.
Old 03-28-2006, 08:54 PM
Senior Member
Well gang, I'm back with my post-repair report....After allowing the new re-seal job to fully cure underneath my cowl/windshield areas of my TB, I will say with some degree of confidence that they stopped the leak, and subsequently, the wet floor on the driver's side...I had my warehouseman at work give her the ole' pressure washer test, blasting everything up front including the onstar antenna seals and she is as dry as a popcorn fart!!!! The dealership has seemed to do another one-trip warranty repair(i'm just wondering when the streak will come to an end?)...I DID have to shame them into shampooing the driver's side carpeting because of the mildewy water that was trapped under my awesome Husky liner mats, but they listened to my righteous mini-rant and obliged...I'm satisfied in knowing that someone at the assembly plant didn't properly caulk(seal) an area underneath the windshield wipers at the firewall...This type of thing is probably not too common, so I don't believe that it is widespread, just a small error of omission...I'm all happy now again and that's that!!! P.S;Nothing personal to all the proud TBSS owners out there(kinda' jealous,in a way) you might blow by me on the roads out there, BUT,I will continue to blast through 3 feet of snow up here in CNY and LOVE EVERY MINUTE OF IT!!!!! We have a sensational website here and let's keep her going!!! Hail to the TB,in all of her majestic forms!!!!
Old 03-02-2007, 09:31 PM
Senior Member
Carpet soaking wet!!!!
I found it, ,iffen you guys need it for info where my leak originated...
Similar Threads
Driver's side foot rest question BLZR SS Interior 31 05-10-2009 11:32 AM
What is the device on the Driver's Side Pillar? jprez1980 Interior 10 09-18-2006 12:05 PM
Trailblazer Passenger Side Heating Help 99redsilverado General 1 09-07-2006 11:08 PM
Driver's Side Heated Seat Not Working Properly gardjosh Interior 4 05-23-2006 11:07 AM
Jiggle noise by the rear driver's side door? New to TB Interior 6 07-22-2005 08:56 AM
