how can I reset oil change indicator - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Engine tuning and/or modifications
Old 09-24-2009, 04:17 PM
sstola sstola is offline
2005 Chevy TrailBlazer LT EXT
Sand Beige Metallic 6.0L LS2 V8 4X4
how can i reset the oil change indicator light on a trailbraizer 2005
Old 09-24-2009, 04:20 PM
gordinho80's Avatar
gordinho80 gordinho80 is offline
2004 Chevy TrailBlazer LS
Welcome and Congratulations! You are the 1000th Noob to ask this question!!!
You win a nice picture with your answer...
Mario -
OffRoadTB.com
Old 09-24-2009, 04:26 PM
2003 GMC Envoy SLT
It depends on whether you have a DIC or not. The owners manual has the info for both. If you don't have a manual they are available in PDF form under the RESOURCES menu above.
Old 09-24-2009, 05:17 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
A question for you? How can you have a 6.0 engine in an EXT?
Old 09-24-2009, 05:20 PM
jaylind jaylind is offline
2007 Chevy TrailBlazer LS
Silverstone Metallic 4.2L I6 2WD
How to Reset the Engine Oil
Life System
The Engine Oil Life System calculates when to change
your engine oil and filter based on vehicle use.
Anytime your oil is changed, reset the system so it
can calculate when the next oil change is required.
If a situation occurs where you change your oil prior
to a change engine oil light being turned on, reset
the system.
To reset the change engine oil light, do the following:
1. Turn the ignition key to RUN with the engine off.
2. Fully press and release the accelerator pedal slowly
three times within five seconds.
3. Turn the key to LOCK.
If the change engine oil light comes back on when you
start your vehicle, the engine oil life system has not
reset. Repeat the procedure.
Old 09-24-2009, 08:16 PM
is a big 6 engine I not sure how but I do!
Old 09-24-2009, 09:09 PM
Super 88's Avatar
Your profile states you have a 6.0 V8 in an EXT. The EXT came with either the 4.2L I6 or the 5.3L V8.
The 6.0 V8 was used in the SS
Old 11-04-2009, 01:02 PM
CHEVYMEX04's Avatar
CHEVYMEX04 CHEVYMEX04 is offline
Black 4.2L I6 2WD
I just wanted to say that I love the TV forum family I had trouble resetting my oil sensor I went to the search engine and I found another member had already answer this question.
Old 11-04-2009, 01:35 PM
Frogbone's Avatar
Frogbone Frogbone is offline
2006 Chevy TrailBlazer LS
http://tinyurl.com/yjugcsa
Old 08-21-2014, 02:55 PM
Goldentoe Goldentoe is offline
2003 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
Thumbs up Resetting the digital oil life indicator
When your oil life indicator needs to be reset from say 62% back to 100%, push and hold the lower right hand button on the stearing wheel until it shows 100% again. These are not real clear instructions in the owners manual.
