Intake Manifold Cover Removal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 09-26-2009, 09:18 PM
slosteve slosteve is offline
1954 Chevy Sedan Delivery
Patina 4.2L I6 2WD
I'm doing a transplant of an I6 and the cover on the intake manifold is close to some sheet metal on my project car. How do you remove this cover and what is it's function (as in - is it needed)?
Old 09-26-2009, 09:36 PM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
#1 or #2?
1 is the intake manifold and not a cover and 2 is a resonator to quiet down the intake and can be removed
Luis
Old 09-26-2009, 10:10 PM
Patina 4.2L I6 2WD
I'm talking about #1 and to me it appears that there is a cover that separates down the center (lengthwise). But before I start getting physical with it I thought that I would see if anyone has removed one.
Old 09-26-2009, 11:17 PM
the roadie's Avatar
It comes off, but the halves are glued together and don't come apart. It's not a cover, it's the manifold itself.
Old 09-27-2009, 07:44 PM
efi-diy efi-diy is offline
Senior Member
1951 GMC 3100 PU Truck
hot rod black turbo'ed 4.2L I6 2WD
If you remove the intake manifold there is a sound deadener that can be removed from the intake manifold. Once its off it'll gain you about 7/16" of room. Its sole purpose is to quiet the intake so it can come off.
The air intake box can be removed also - but the intake is noisy so be aware.
Turbo'ed 4200 @ 10 PSI == 510 RWHP 500 LB/FT Torque Rear wheel
Old 09-27-2009, 11:29 PM
Patina 4.2L I6 2WD
Thank you!
Old 09-28-2009, 02:05 AM
_GTO_'s Avatar
_GTO_ _GTO_ is offline
2005 Chevy TrailBlazer LT EXT
Black 4.2L I6 2WD
So , will it gain any Hp ?
