[SOLVED] Headlights wont turn off - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-27-2009, 03:59 PM
Big Ern Big Ern is offline
2003 Chevy TrailBlazer LT EXT
My 2003 TB battery died - must have had something left on, only clicks on attempting to start, but the weird thing is that the headlights turned on by themselves with the switch off, and will not turn on or off. Anyone see this before? If so, what is the fix? I have my duramax van hooked to it now for jump starting, as the batt is low enough that the charger won't even send it a charge.
Thanks for the help
Old 09-27-2009, 04:10 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Relay stuck in on position. You need a new one
Hi-beam is relay # 43
Low-beam is relay # 46
Both are in the underhood fuse panel.
Ray
Old 09-27-2009, 04:26 PM
Chevy-TB-lover's Avatar
Chevy-TB-lover Chevy-TB-lover is offline
2007 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
One of the LED gods around here!
Old 09-27-2009, 05:30 PM
the roadie's Avatar
Ray, you forgot your reading glasses. It's #46 for the low beam. I fixed it.
Old 09-27-2009, 06:27 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Thanks Bill, must have been the rum and ginger
Ray
Old 09-27-2009, 06:54 PM
Thanks guys - after the truck started and the battery charged, the lights started working normally again.
Old 09-27-2009, 07:30 PM
dirtychevymama's Avatar
dirtychevymama dirtychevymama is offline
2003 Chevy TrailBlazer LTZ
White/Pewter North Face 4.2L I6 4X4
Big Ern, you can mark this thread solved I do believe :O)
Old 01-26-2012, 01:42 AM
Old Blue Old Blue is offline
2002 Chevy TrailBlazer LTZ
i just started having this problem today. would it also be the relay if i have hids.
3.73 gear ratio, Aero chamber muffler, Resonator delete, 6k hid, Drilled slotted brakes, Marvel mystery oil, Diamond White
Old 06-08-2013, 03:47 PM
suzgonz suzgonz is offline
2007 GMC Envoy Denali
Summit White 5.3L V8 4X4
Thank you
Just had that issue with my Envoy...and you were right... It was the fuse! Thanks so much!!!
Old 06-11-2013, 10:50 AM
hpmccut hpmccut is offline
2004 Chevy TrailBlazer LT
Automatic Headlights turn on while vehicle is off....
Have a different problem I have never run in to before.... My headlights randomly come on while the Trailblazer is parked! Here is the background so far:
Came out of work last night to find a dead battery. Jumped it, and put it on the charger when I got home. The headlights were off.
Went out with my wife in her car, leaving the charger on automatic for an hour. When we got home, the lights on the TB were ON. Flicked a couple of the switches and they went off. Let the battery recharge again without the light coming on, and disconnected the battery for the night.
Drove the TB to work this morning, and parked it facing my office window where I could see it. Lights went off after the standard delay when the car was shut off. 45 minutes later, I noticed the lights were ON! Flicked the high beam switch on the steering column once to engage them, and the low beams shut off.
Other notes: Its been cloudy & rainy the past 2 days in that area, so the general light level is lower. Also, I just passed 200,000 miles a week ago, but I didn't celebrate so maybe it is just being cranky.....
Any insight as to were to look at the fuse/electrical system would be greatly appreciated!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
