loud whirring noise - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-02-2009, 12:27 PM
fasheeryfo fasheeryfo is offline
2002 Chevy TrailBlazer LS
loud whirring noise
when I accelerate (I also put the car in neutral and revved) so basically when the RPM's go up, my car is making a whining/whirring noise. It was perfectly fine until this morning when I got in it.
got in my car, started it up. No noise
put in reverse, when applying the brakes after backing out of my parking spot, started shaking/shuddering and then when I applied the gas, started whining kind of a high pitched noise or like the whine of a vacuum cleaner. Any suggestions?
Old 10-02-2009, 12:32 PM
antiminivan antiminivan is offline
2003 Chevy TrailBlazer LT EXT
Black 4.2L I6 4X4
If it's linked to engine speed, a likely (and inexpensive) culprit is the idler pulley.
Old 10-02-2009, 02:25 PM
the roadie's Avatar
But the shaking/shuddering could also be a failing/failed PS pump, water pump or AC compressor bearing.
Best to pull the serpentine belt (search for many threads discussing how - it's simple) and turn pulleys by hand and see if any of them are grinding.
Old 10-02-2009, 04:42 PM
I will look into that when I get home from work.
On a side note, my dad heard the noise and was like sounds like your power steering fluid... I dunno how the increased RPM's would affect the sound if that were the issue, but it turns out the power steering fluid was pretty dry (still wet inside but no visible level of fluid)
could this have anything to do with it?
**just realized you said something about the PS pump, i didn't make the connection before haha**
Old 10-02-2009, 05:19 PM
Black 4.2L I6 4X4
Absolutely. The PS pump is belt driven, so it would be spun faster as the engine spins faster.
Old 10-03-2009, 11:05 AM
put in fluid, turns out I have a leak that is dripping down somewhere near the drivers side tie rod.
The noise stopped when I put the fluid in and it doesn't seem like my power steering is going, should I replace the pump or could it be a line or something?
The drip doesn't seem to be too serious, I filled the resevoir to the "H" line on the dip stick, today it is at the "C" line like 3-4mm less than yesterday. It's been about 15 hours of sitting overnight and an hour of driving altogether after putting the fluid in yesterday.
