Spare tire won't lower. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-10-2009, 04:56 PM
c good c good is offline
Senior Member
2002 GMC Envoy SLT
The spare begins to drop down then just stops, no matter how much I turn the handle. If I reverse direction (clockwise) it will pull the tire back up and hold it securely. Any suggestions on fixing this?
Old 10-10-2009, 05:06 PM
Teacher's Avatar
Teacher Teacher is offline
2008 GMC Envoy SLT
Liquid Silver Metallic 4.2L I6 4X4
Drop it down as far as possible and then spray some WD40 on the mechanism. Raise and lower it a few times and hopefully it will break free. Good luck!
South Chapter
Colorado Rep
Old 10-10-2009, 07:23 PM
sse1990 sse1990 is offline
2002 Non-GMT360 Other
Black Other 2WD
In the manual it says to raise it back up til it clicks I think 3 times then back down and repeat a few times. It took me more than that to get it down. I would get something better than WD-40, but same idea. There is PB blaster and I use a product called release-all, same price as WD but WAY better. Then let it soak and repeat the up and down thing a few times.
Old 10-10-2009, 07:55 PM
xhondastyle07x's Avatar
xhondastyle07x xhondastyle07x is offline
2005 Chevy TrailBlazer LS EXT
Black 4.2L I6 4X4
You may have to apply a little downward pressure in the tire/rim. My cable didnt stick but the part that slides on it was. Pulling down a little was all it took to get it there.
GO BIG OR GO HOME !!
Old 10-10-2009, 08:12 PM
Senior Member
2002 GMC Envoy SLT
Which mechanism do you recommend lubing? The secondary latch assembly or the cable/winch set up? Thanks for any input.
Old 10-10-2009, 08:15 PM
lynch55's Avatar
lynch55 lynch55 is offline
Black 4.2L I6 4X4
Everything and anything you can get to! You can't hurt nothing by lubing everything!
Old 10-10-2009, 08:41 PM
Stinkpickle88's Avatar
Stinkpickle88 Stinkpickle88 is offline
2004 Chevy TrailBlazer LS
hmmm
Old 10-10-2009, 10:59 PM
Black 4.2L I6 4X4
I lowered mine all the way then used grease on the cable and latch assembly to keep it from siezing
Old 10-11-2009, 12:57 AM
Dizzlenator's Avatar
Dizzlenator Dizzlenator is offline
Northeast Chapter
2004 Ford F-250 Powerstroke Diesel
Gray Other 4X4
Mine wouldn't work either. I lowered it completely, messed with the cable, etc, and it wouldn't come down. Had a buddy come over, and we sat behind the truck, and kicked the holy crap out of it until it fell. I lubed the cable, and everything, and got nothing. Found my winch system to be torn up, and broken apart. Once he came over, and we both kicked it a bunch (4-5 mins) it finally fell...full size spare is mounted in my roof basket, so I didn't need the stocker....so mine is sitting in my garage...
04 F250, 04 Mustang w/ boost, but she might be going away soon
Old 10-12-2009, 08:53 PM
SilveRadix SilveRadix is offline
2003 Chevy TrailBlazer LT EXT
I pried on mine with a shovel while my friend turned the handle.
