Occasional traction control light - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-12-2009, 08:26 PM
C and C C and C is offline
2008 Chevy TrailBlazer LS
Very Dark Cherry 4.2L I6 4X4
I have had the traction control warning and service lamps come on while backing out of my driveway a couple of times. I have owned my '08 TB for 4 months and I reset it by shutting off the ignition and restarting. I have to turn sharp due to the shape of my dirveway and I am wondering if it is sensitive to the sharp turns. It has never come on at any other time. Should I be concerned?
Old 10-19-2009, 01:31 PM
Atlwrk's Avatar
Atlwrk Atlwrk is offline
2006 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
I've had my lights come on two or three times in the last few months--also able to reset by turning off the engine and restarting.
I suspect that a wheel-speed sensor (straining a loose connector/wire during a hard turn) may be causing the issue but that's not much more than speculation at this point. Unfortunately intermittent faults like this are gonna be buggy to sort out.
Not much help, but at least you're not alone.
Old 12-06-2009, 01:57 PM
01YZF6's Avatar
01YZF6 01YZF6 is offline
Dark Cherry Metallic 4.2L I6 4X4
I was going down the road today at 35 mph and the Traction off light (triangle with skid marks?) and the traction light with a wrench came on too simultaneously. (directly to the left of it.)
pushing the button on the shifter did nothing and holding it down for 5 seconds caused it to blink a few times but still stayed on.
anyone else have these issues or a possible solution? is there anything the dealer can do about it?
I still have a 30 day "fix-it all" grace period with them.
thanks
Technically its the Wife's Truck, so I'll ask her and get back to you on that...
Old 12-06-2009, 02:39 PM
the roadie's Avatar
It's out of factory warranty already? Anyway, if you have a 30-day used car warranty, the dealer MUST deal with it. Could be a couple of dozen wiring, sensor or control module issues. Much better diagnosed by somebody with training and a GM tech tool, not a DIY sort of system.
Old 12-06-2009, 06:39 PM
01YZF6's Avatar
yes it was a used purchase so factory warranty out of the question. I will call teh dealer tomorrow and let them know !
Old 01-18-2010, 01:47 AM
Brian P's Avatar
Brian P Brian P is offline
2008 Chevy TrailBlazer LT
Graystone Metallic 5.3L V8 4X4
any update on this? I had this come on twice so far immediately after a cold-start (a shut down and restart fixed it) but I also had a low tire at the time. After re-inflating all to the correct pressure it hasn't happened since...
2008 Chevy Trailblazer LT 5.3
1995 Olds Cutlass Supreme SL coupe 3400 V6
Old 01-18-2010, 01:51 AM
Teacher's Avatar
Teacher Teacher is offline
2008 GMC Envoy SLT
Liquid Silver Metallic 4.2L I6 4X4
If you have OnStar connect with them when the Service Stabilitrack light is on and have them run a diagnostic. They'll be able to tell you what sensor is causing the light. The light must be on for them to check it though. Good luck!
South Chapter
Colorado Rep
Old 01-18-2010, 08:44 AM
mwfaith1971 mwfaith1971 is offline
2002 Chevy TrailBlazer LTZ
Black Other AWD
Can I ask a stupid question?....08 would have a 100,000m or 5 year warranty even if used wouldn't it? I thought the warranty transferred with ownership until either of the two things above occurred.
Matt
Old 01-18-2010, 10:46 AM
Brian P's Avatar
5 yr/100k is not a bumper-to-bumper but a powertrain warranty. As such I don't believe GM would cover a malfunction of the traction control system.
Old 01-18-2010, 05:32 PM
sustorm sustorm is offline
2007 Chevy TrailBlazer LS
I am having the same issue with my 07, i have about 45K on it and both lights have been coming on random 4-5 times in the last 2 months. They also can be reset by turn off the ignition and back on again. Any insight would be appreciated.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
