OEM Bose 6 CD changer has CD mode froze? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-14-2009, 11:11 AM
NickRummy's Avatar
NickRummy NickRummy is offline
2006 Chevy TrailBlazer LT
Dark Spiral Gray Metallic 4.2L I6 4X4
My sister had a CD in that was skipping so she tried ejecting it and the thing just simply stopped working. Shows the clock to the left hand side but will not allow you to do anything in the CD player mode. You can still switch to the radio with no problems. when you're on the radio mode it shows a flashing CD up by how many CDs are in the deck if that might help diagnose the problem.
I did some searching and all I could find that might fix it would be disconnecting the radio harness and letting it sit for a couple minutes to reset itself. Any other ideas and is the radio harness hard to get to?
Old 10-14-2009, 11:22 AM
GusMan GusMan is offline
2003 Chevy TrailBlazer LT EXT
Majestic Red Metallic 5.3L V8 4X4
If all you want to do is kill the power to the radio for a bit, I would think that pulling the fuse would do the trick. It may or may not do the trick, but it is at least a try before taking apart trim pieces to get to the radio.
Let me ask this... is it making any sound when engaging CD mode?
Old 10-14-2009, 11:37 AM
NickRummy's Avatar
It makes no sounds at all when going to CD mode
Would the fuse cut ALL power to the radio or just the main feed? I know a lot of radio also have remote power lines to keep memory and all that stored. I was thinking those lines would have to be disconnected also to truly reset it all.
Old 10-14-2009, 11:04 PM
chevtrlblzr's Avatar
chevtrlblzr chevtrlblzr is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I'm not sure, but unhooking the battery cable will cut the power - and is easier than the radio harness.
Worth a try before replacing it.
- Carlisle Truck Nationals
Aug 5 - Aug 7, 2011 - Was Awesome
Old 10-15-2009, 12:37 AM
4x4forLIFE's Avatar
4x4forLIFE 4x4forLIFE is offline
2005 Chevy TrailBlazer LS
Majestic Red Metallic 4.2L I6 AWD
make sure you keep the cable unhooked for a good five mins or more at least.
i had my radio out for about 5 maybe a tad more and put it back in an all my stations and cd playback times and clock were stiil there lol
kinda crazy but my cd player did the same thing. i just hit eject and sat and had a smoke and by the time i was done it popped out
