Buick Rainier
TrailVoy.com is the premier Chevy TrailBlazer and GMC Envoy Forum on the internet. Registered Users do not see the above ads.
Old 10-28-2009, 07:55 AM
KIDRIP8 KIDRIP8 is offline
2003 Chevy TrailBlazer LS
One Headlight does not work
Hello everyone I am new here. I have a 2003 Trailblazer. My drivers side Headlight went out. I replaced the bulb and it still does not work. I looked at the connection and it is not burned or black (happened on the passenger side). I am not real good with cars so I am asking does anyone know why this may not be working? Any tricks I can try? Thanks in advance for any help.
Bryan
Old 10-28-2009, 08:10 AM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
Unfortunately, where parts swapping ends, troubleshooting begins.
Do you have access to a digital multimeter or 12v test light?
Old 10-28-2009, 09:31 AM
Diablo03's Avatar
Diablo03 Diablo03 is online now
Pewter Metallic 4.2L I6 4X4
could be a fuse? is anything else out on the truck? anything else not work?
Midwest Chapter MO member
need 1G DSM parts?....click me
Old 10-28-2009, 09:32 AM
christo829's Avatar
christo829 christo829 is offline
Senior Member
2004 Chevy TrailBlazer LT
I don't have the manual here at the moment, but check the under hood fuse
block. There are individual fuses for passenger side and driver's side high
and low beams. All I can find for diagrams at the moment is info for
an 07 TB:
Fuse 2 Passenger High Beam
Fuse 3 Passenger Low Beam
Fuse 5 Drivers High Beam
Fuse 6 Drivers Low Beam
Check with meter or just swap them and see if the problem travels.
Good Luck!
Old 10-28-2009, 10:06 AM
Well I pulled the fuse and it was fine. I was really hoping that was it. I do nto have a meter here at work or anywhere for that matter. Thanks for trying.
Old 10-28-2009, 11:09 AM
MAY03LT's Avatar
TrailVoy Guru
For less then a single trip to a shop for a diagnosis, an investment in a meter will help troubleshoot electrical problems for years to come.
Old 10-28-2009, 11:17 AM
Dizzlenator's Avatar
Dizzlenator Dizzlenator is offline
Northeast Chapter
Scratchy, dirty blue 4.2L I6 4X4
GREAT ADVICE!!
04 "Z71" on BFG's
Old 10-28-2009, 11:19 AM
christo829's Avatar
Senior Member
Not only will it allow you to test that headlamp connector,
but also voltage at the fuse box, and continuity on the fuse. Sometimes
fuses will look ok, but still be bad. I had one on my Lumina that looked
fine, but had no continuity. I had to look at it with a magnifying glass
to see the break.
You could have something as simple and annoying as a poor connection
inside that connector....you can't see all of it, but what you can see
looks ok. A meter could at least help you narrow down the possibilities.
Got a Radio Shack near you?
Good Luck!
Old 10-28-2009, 12:38 PM
the roadie's Avatar
Super Moderator
A year or so ago, Harbor Fright had a sale on cheap meters. Like $1.99 cheap. I bought a dozen, and whenever I have somebody local want to borrow my good meter, I throw them one of these cheapies and give them a 2 minute tutorial.
If they didn't learn the difference between volts and amps in high school, they might not be trainable, though. How is it possible to graduate without learning the bare minimum about how the world works? Is physics not a required subject anymore?
Bill Videos Build Thread
Offroad Guru
Old 10-28-2009, 02:26 PM
07_TB_RIDER's Avatar
07_TB_RIDER 07_TB_RIDER is online now
2007 Chevy TrailBlazer LS
Light Tarnished Silver 4.2L I6 4X4
Gotta give it up to MAY03LT and roadie
We live for the nights we'll never remember with the people we'll never forget.
South Chapter Oklahoma Member
-Mike
You may not post new threads
You may not post replies
