How to: Replacing spark plugs in an I6 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 11-08-2009, 10:39 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
Video Error
Tools used:
Flathead screwdriver
Mini pick
Pliers (ok I used wire strippers but needle nose pliers or dykes should be used)
1/4" ratchet, extension, 10mm socket
Swivel spark plug socket, locking extension, extension
Big 3/8" ratchet, stubby 3/8" ratchet
Procedure: A more detailed step by step can be found here.
Remove intake box
Reposition wire harness
Remove coils
Remove plugs
Coat tips of plug threads and coil bolt threads with anti seize
Install plugs
Install coils
Install intake box
Note: the wire harness cover does not have to be removed, I removed it to show a good view of the clips.
Note 2: I didn't show the small vac line get disconnected prior to removing the intake box. It does have to come off.
Old 11-09-2009, 08:46 PM
mikespine's Avatar
mikespine mikespine is offline
2003 Chevy TrailBlazer LTZ
Graphite Metallic 4.2L I6 4X4
Thanks for taking the time to make the video. (Probably because of my computer..it was a "choppy" download.) Good work-Mike
K&N CAI-FIPK, HD Bilstein
Old 11-09-2009, 08:50 PM
MAY03LT's Avatar
TrailVoy Guru
Did you try to watch it in HQ?
Thanks for the feedback!
Old 11-09-2009, 08:58 PM
ShawnAndrewMAC's Avatar
ShawnAndrewMAC ShawnAndrewMAC is offline
2007 Chevy TrailBlazer LS
Silverstone Metallic 4.2L I6 2WD
Great vid!
Old 11-09-2009, 09:15 PM
MAY03LT's Avatar
TrailVoy Guru
Originally Posted by ShawnAndrewMAC View Post
Great vid!
Thanks man!
Old 11-09-2009, 10:00 PM
ruvalcaba's Avatar
ruvalcaba ruvalcaba is offline
2003 GMC Envoy SLE
Black 4.2L I6 2WD
great video and is very easy to understand
Old 11-10-2009, 09:43 PM
Mike616 Mike616 is offline
2005 Chevy TrailBlazer LT
Onyx Black 4.2L I6 4X4
Thumbs up
Great video! Thanks for taking the time!
Old 11-10-2009, 09:54 PM
Foosh's Avatar
Foosh Foosh is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Great Video, One of the best that i've seen!
-Tom
Z71 Lifted TB on 33's
Old 11-10-2009, 10:20 PM
MAY03LT's Avatar
TrailVoy Guru
Old 11-10-2009, 10:40 PM
lynch55's Avatar
lynch55 lynch55 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Hell Yea! Nice little un-boring vid! Only things I did different was I didn't move the plastic wire cover(just pried it back) and used air! Oh, and my assistant didn't sound neeeear as sexy as yours! Cool deal friend!
Tags
a/c delco 41-103, coil replacement, how do i shoot plugs?, plug swap fever, spark plug replacement
