help needed to lower the spare tire - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-24-2006, 09:45 PM
TBJosh TBJosh is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
I bought my trailblazer a couple of months ago ... used. Early this morning, I went out to the garage to find my tire really flat. I needed my spare and when I opened the back seat to get the metal bars, I find that I am missing a piece. It's the piece that slides into the hole in the back liftgate to crank down the spare tire. (I do have the extension and lug breaker bar.) I can't see what is needed to fit in the hole (socket or otherwise). Does anyone have any ideas what to do? Maybe a dealer part number or something I can piece together that will work? Thanks.
Old 03-24-2006, 09:48 PM
homertime's Avatar
homertime homertime is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I think you can slide underneath the truck and do it manually... there may be some sort of lug nut there or something...
Old 03-24-2006, 10:18 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
A long flat-head screw driver will usually do the trick. Peek thru the hole with a flashlight to see what shape the receiver tube is. You should be able to rig up something to rotate the tube.
G/luck
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 03-25-2006, 01:15 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
Just to let you know, I think the lug nut wrench has a pointed end to it with a plastic covering over it. Remove the plastic and insert the pointed end into the spare tire hole. Also, this pointed end is used to remove the center caps of the tires.
Old 03-25-2006, 06:41 AM
tahawus84's Avatar
tahawus84 tahawus84 is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
you can also use a deep socket and a long extension rod. I figured this out when I was 300 miles from home and realized i didnt have the special tool to remove the tire.
Old 03-27-2006, 11:24 AM
220com2's Avatar
220com2 220com2 is offline
2003 Chevy TrailBlazer LS
dose any one have the problem of the cable that lowers the tire down binding or wrapping around itself so the tire only comes down halfway??
-Jason
03 Trailblazer LS
03 Jeep LIberty Limited
Old 03-27-2006, 12:33 PM
chunn7 chunn7 is offline
2007 Chevy TrailBlazer SS
Red Jewel Tintcoat 6.0L LS2 V8 2WD
I hate the spare tire and jack set up in the TB! If you're not too car saavy (like me) it's nearly impossible to get the spare out. Then I tried to use the jack and it broke. Dealer had to order another one. What an ordeal!
Old 03-27-2006, 08:49 PM
MTPockets's Avatar
4.2L I6 4X4
I've had similar things happen on other trucks. You might wanna order a new winch kit before she locks up totally on you. Best PM you can do to these winches is 'exersize' them atleast once a year. Throw a little grease on the cable as well.
Joel
Old 03-28-2006, 12:33 PM
bmm354's Avatar
bmm354 bmm354 is offline
2002 GMC Envoy SLT
Sandalwood Metallic 4.2L I6 4X4
TBJosh - If you haven't got your hands on the part yet, try calling a salvage yard. They'd prob. sell you the tools for a few bucks.
Yes - had this happen and it drove me nuts until I realized what was happening. On mine the cable just kept wrapping itself around the inside of the little housing it's supposed to drop out of. Fortunately it was a simple fix to reach up inside the housing and pull the cable free. Nothing was broken and everything was turning free, it's just that the cable was winding itself in a coil inside the housing instead of dropping out.
I'm just glad I tried lowering the spare as a test at home (and also to lube up the mechanism). I wouldn't have been too happy figuring this out if I had a flat.
2002 Envoy SLT, 116K
Sandalwood Metallic
Old 03-28-2006, 01:00 PM
EnvoyXL's Avatar
EnvoyXL EnvoyXL is offline
2006 GMC Envoy SLT
Red Jewel Tintcoat 4.2L I6 2WD
You never get a flat anytime or anyplace it is convenient.
Similar Threads
code p0014 Jbird13329 OEM Issues 11 03-05-2014 08:41 PM
HOW TO install a cam ? dv_tbss06 Engine Tunes/Mods 15 08-29-2011 07:20 PM
Gunk in the coolant reservoir? bugeyed OEM Issues 17 01-16-2010 11:55 AM
Saturn Outlook NC Trailblazer Latest GM News 15 03-24-2007 10:06 AM
Does Santa Claus Exist? Stan Everything Off-Topic 0 12-22-2006 01:53 PM
