Starter problems 2006 ss - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > OEM Issues
OEM Issues Original Equipment Repairs/Problems
Old 11-28-2009, 09:38 AM
hoeflby hoeflby is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Unhappy Starter problems 2006 ss
SS has been starting fine... Got a little cold out now no go. I get a loud click noise but thats is. Anyone have any ideals??? PLease help
Old 11-28-2009, 01:02 PM
the roadie's Avatar
If you get a loud click, then the ignition switch, relay in the fuse box, and most of the wiring seems OK. Check with a meter on the starter to make sure it gets its main power feed, then you might conclude you need a new/rebuilt one. Whack on it as somebody turns the key to see if you have a sticky solenoid.
Old 11-28-2009, 04:05 PM
lynch55's Avatar
lynch55 lynch55 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Welcome! And it's a booger to get to!
Old 04-03-2010, 05:13 PM
jimmyjam's Avatar
jimmyjam jimmyjam is offline
TrailVoy Guru
2006 Chevy TrailBlazer SS (LT)
White 402ci Other AWD
has anyone replaced a starter in an SS? how the hell do you get it out / in? i'm sure you've got to remove something
solenoid stuck on me yesterday so i figured i'd preempt it happening again by replacing it. gave up after a few hours
Old 04-03-2010, 06:12 PM
lynch55's Avatar
Black 4.2L I6 4X4
Check the search function and type in starter removal. Good Luck!
Old 04-04-2010, 02:22 AM
jimmyjam's Avatar
TrailVoy Guru
thanks for that magic keyword. ooof this is gonna suck
Old 04-15-2010, 10:22 PM
DavidWSS DavidWSS is offline
2008 Chevy TrailBlazer SS (3SS)
Onyx Black 6.0L LS2 V8 AWD
did you boost it?
Old 04-15-2010, 11:32 PM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
Someone posted instructions a while back and it involved the Y pipe
Luis
Old 04-15-2010, 11:55 PM
jimmyjam's Avatar
TrailVoy Guru
if you search starter removal, there is a thread with the factory manual instructions which include removing the steering gear crossmember. didn't get to it last weekend
here it is
http://forums.trailvoy.com/showthread.php?t=54226
Old 06-12-2010, 12:39 AM
Another BlackSS's Avatar
Another BlackSS Another BlackSS is offline
2006 Chevy TrailBlazer SS (3SS)
yea this isnt that bad of a job. Just romove the crossmember bar that has like 8 bolts in it and strong arm it out
You may not post new threads
You may not post replies
